MSD Wiring (Engine Run-On)
Old Jun 20, 2002 | 10:12 PM
pingdashf's Avatar
pingdashf
Default Should I Install a Switch? (MSD Wiring and Engine Run-On)
MSD intructions are to take the "wire that went to the positive terminal on the coil and wire it to the light red wire from the MSD 6AL."
My positive terminal has TWO wires. Actually 3, but only two that are possibly from the ignition. One of them only has juice when the key is turned all the way up (ie, when starting the car).
The other wire only has juice once the car is started.
I have two problems, #1, which of these wires is the actually ignition wire, or are both of them the ignition wire? and #2, how do I solve the run on? MSD Suggests that I install a resistor either between the ignition and the 6AL or on the alternator. Which should I do? Has anyone else run into the problem?
My Stock Coil:
[Modified by pingdashf, 7:38 PM 6/21/2002]
Old Jun 21, 2002 | 11:41 AM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: MSD Wiring (pingdashf)
The wire that has power only when starting is for cold weather starting and is not needed.
The other wire should have power anytime the key is in the 'RUN' position, that is the one MSD wants you to connect to...
Don't know about the run-on, sorry
[Modified by 427V8, 9:42 AM 6/21/2002]
Old Jun 21, 2002 | 11:52 AM
Gordonm's Avatar
Gordonm
Default Re: MSD Wiring (427V8)
The small red wire from the MSD unit needs 12 volts when the ignition is on. You can use the one at the coil or route your own for 12 volts ignition on.
Old Jun 21, 2002 | 01:44 PM
pingdashf's Avatar
pingdashf
Default Re: MSD Wiring (Gordonm)
Running my own Ignition would be a pain in the butt, no?
Old Jun 21, 2002 | 03:38 PM
pingdashf's Avatar
pingdashf
Default Re: Should I Install a Switch? (pingdashf)
I could install a switch to turn the car off, anyone have issues with that?
Old Jun 21, 2002 | 04:20 PM
Gordonm's Avatar
Gordonm
Just find out which wire going to the coil is hot when the ignition is on and use that one. You can also find a hot ignition lead off the fuse box if needed. No need to add more switches than needed.
To MSD Wiring (Engine Run-On)
