Rear air shock question
Old Apr 25, 2013 | 08:32 PM
buffblazer's Avatar
buffblazer
Default Rear air shock question
Was looking a my strut rods the other day to see what all I needed to replace and noticed that my 75 has air shocks with air lines running to the rear of the car.
Traced the air line and found a fitting in the rear bumper. Both shocks are connected to the one fitting which I'm assuming was to try and keep equal
Pressure on both of them.
Are air shocks worth keeping on or should I go with a regular gas style tube? And if they are worth keeping on, what kind of PSI should I run for normal driving?
Old Apr 25, 2013 | 08:35 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hmm,
problem is the air pressure will raise the rear height.
wonder what PO was doing?
Old Apr 25, 2013 | 09:18 PM
TEXASDESERTVETTE's Avatar
TEXASDESERTVETTE
Well , raising the rear ride height is what they are used for...I use mine to help get over speed bumps,due to the '77 custom exhaust set-up...And of course I also pull a '77 BAJA 15 foot run-about ski boat rig. Onboard air compressor and control valve set up for ease push button operation...
As far as the air pressure ...for the street and road ...I just give them a little positive pressure just enough to fill the bladders somewhat and let the shocks do their thing...also the car is fitted with the VB&P front and rear dual mount suspensions...
Old Apr 25, 2013 | 11:43 PM
7t9l82's Avatar
7t9l82
it will handle better with 2 lines not tied together. as one side compresses the other tries to raise
Old Apr 25, 2013 | 11:52 PM
Tim H's Avatar
Tim H
I heard that separate air lines is illegal due to if one line busted that the car could flip?
When you buy them new they come with 1 fill port for a reason.
I would get rid of them no matter what, if you need the car up in the air screw the leaf spring nuts up the bolt.
Old Apr 26, 2013 | 01:22 AM
7t9l82's Avatar
7t9l82
b.s.
To Rear air shock question
