over flow tank radiator 72 vette
Old Apr 26, 2013 | 03:57 PM
knevil's Avatar
knevil
Default over flow tank radiator 72 vette
Wanting to add a over flow tank to my 72 stingray 350 with a/c . need to know what parts I will need as my vette doesn't have one now . Any pics of location of tank in car would be very helpful
Old Apr 26, 2013 | 03:58 PM
MelWff's Avatar
MelWff
When you say overflow tank do you mean a aftermarket plastic bottle? If so isnt there a bare spot on the passenger side inner fender?
Old Apr 26, 2013 | 04:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Aluminum radiators require the surge tank. Copper/brass radiators do not use the surge tank. My guess a 72 with factory air probably used the copper/brass radiator.
The assembly instruction manual (AIM) shows how the tanks and brackets mount on the RH fender skirt.
Old Apr 27, 2013 | 10:39 AM
gerry72's Avatar
gerry72
You could put a '73 recovery tank on the '72, but it's really not necessary and, as long as your cooling system is up to snuff, adds nothing to performance or reliability. If your cooling system has flaws, better to fix those than put band aids around the problem. If your system is puking coolant, then make sure you have not over-filled the radiator and have a properly functioning radiator cap. The expansion space in the radiator needs to be maintained to ensure you don't puke coolant.
Old Apr 27, 2013 | 11:01 AM
Mike Ward's Avatar
Mike Ward
Why, it's worked just fine for 41 years without one.
Old Apr 27, 2013 | 01:47 PM
knevil's Avatar
knevil
Thanks for the great info . cooling system working fine . Guess i'm being **** as usual , probably just over filling coolant . Again thanks for your thoughts .
Old Apr 27, 2013 | 02:05 PM
Manuel Azevedo's Avatar
Manuel Azevedo
On my 68 with air and the copper brass radiator my system would find a level in the radiator just fine and would never run more than 200 with the 185 thermostat, no problem. But then I added the surge tank to keep the radiator full, and after doing that I stay at the thermostats temp all day no matter how hot it is out side. So I would say if your not concerned about original then add the tank for sure.
Old Apr 28, 2013 | 12:23 PM
Easy Mike's Avatar
Easy Mike
...probably just over filling coolant...
Check your owner's manual. Most copper/brass radiators fill to within one inch of the bottom of the fill neck. They need a coolant expansion space.
Old Apr 28, 2013 | 12:25 PM
Mike Ward's Avatar
Mike Ward
That would be a coolant recovery tank, not a surge tank. Very different animals.
Old Apr 28, 2013 | 12:29 PM
Manuel Azevedo
So explain what you think is different?
Old Apr 28, 2013 | 12:58 PM
Mike Ward's Avatar
Mike Ward
A 'surge' or expansion tank is part of the pressurized side of the system. A coolant recovery tank (as seen on '73 and up Corvettes) is unpressurized.
A surge tank still needs air in it to allow for coolant expansion.
To over flow tank radiator 72 vette
