Power steering
Old Apr 26, 2013 | 07:07 PM
redwhitekat's Avatar
redwhitekat
Default Power steering
My power steering feels weak steering doesn't return with ease maybe its just the way these were built but with a new modern pump does it improve ?? Have u guys that replaced one notice any difference ? Current pump still works not noisy or anything
Old Apr 26, 2013 | 08:40 PM
couperdecar's Avatar
couperdecar
I just added a $20 pressure reducing kit to reduce the pressure from stock 1200 lbs to 850 lbs for my power steering pump. Here is a link to a fellow who took his pump off and installed the kit. You can jack your car up crawl underneath and modify it with the pump still on though. Instead of adding a washer like this fellow does to decrease the pressure , remove a factory washer to bump the pressure up. When you do it you WILL need a magnet to get the relief valve out of the power steering pump.
Old Apr 26, 2013 | 08:57 PM
redwhitekat
So by increasing the pressure will it make the pump more responsive
Old Apr 26, 2013 | 10:18 PM
Peterbuilt's Avatar
Peterbuilt
Your valve might just be stuck but if your going in there see post 5 by Jim Shea.
http://forums.corvetteforum.com/c3-t...some-help.html
Old Apr 26, 2013 | 10:19 PM
Jim Shea's Avatar
Jim Shea
If you increase the flow from the pump you will make the valve more responsive and the steering will feel lighter. If you increase the maximum pressure from the pump you will cause the hose fittings to leak.
Jim
Old Apr 27, 2013 | 12:04 AM
redwhitekat
Any one know a good kit to buy and just replace the control valve. I'm gonna take Jim's advise and get that end fitting from an astro van to get more flow
Old Apr 27, 2013 | 10:31 AM
gerry72's Avatar
gerry72
I'd be looking into an alignment check before I started throwing parts at the problem.
Old Apr 27, 2013 | 10:40 AM
redwhitekat
There's no problem just had my alignment done I'm just seing how I can get my power steering more responsive
To Power steering
