Is My Timing Chain Timing Correct?
Old Apr 27, 2013 | 03:52 PM
TedH's Avatar
TedH
Default Is My Timing Chain Timing Correct?
I don't have a second pair of (shade tree mechanic's) eyes locally so thought I would post this picture to get opinions. Want to be SURE before I button this up for the final time. Don't want to lunch this engine after all of the work to install the retro-roller kit.
I had eyeballed it when I set it up but then, had second thoughts as I buttoned it up. So, this time, I've put a mirror where the radiator was (that is why the engine looks 'reversed') and shot a pic with my smartphone.
Counting the teeth on the crank sprocket, there are 4 to left and right and it looks 'straight up' with the cam sprocket.
Good to go?
Old Apr 27, 2013 | 04:02 PM
TedH's Avatar
TedH
this may help (darkened the lower mark).
Old Apr 27, 2013 | 04:17 PM
7t9l82's Avatar
7t9l82
looks fine, should be good to go
Old Apr 27, 2013 | 04:26 PM
TedH's Avatar
TedH
Thanks! Just needed that second pair of eyes. Going to close it up now.
Old Apr 27, 2013 | 04:34 PM
Jeff_Keryk's Avatar
Jeff_Keryk
She should fire right up and idle...
Old Apr 27, 2013 | 04:45 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
OK! Dot-to-dot puts #6 in firing position.
Just be sure that your indexing of the 3 keyways with their associated marks is correct (couldn't see from the pix), otherwise you may be advanced or retarded by 4 degrees.
Old Apr 27, 2013 | 05:19 PM
TedH's Avatar
TedH
Yep. The crank gear is set up correctly. Thanks for checking.
Old Apr 27, 2013 | 05:38 PM
TedH's Avatar
TedH
Just pressed the damper back on the crankshaft. The comp install tool stopped and I thought I should be sure it was all the way on the crankshaft. Put a screwdriver in the flywheel and gave the tool one more good pull and, well, this just all got a lot more expensive...
The other end is in the snout of the crankshaft threads. Twisted it off in the crankshaft.
I think this engine has to come out now.
Damn!!!
Old Apr 27, 2013 | 08:42 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Ted..
I'd try two things first..
1) Get a drill and drill in it a little bit. Then reverse direction and see if it spins out. Since the puller/installer is not under load it may just unscrew without pulling anything.
2) I'd try drilling it out and then use an easy out on it... again hoping it spins out.
IMHO,
Willcox
To Is My Timing Chain Timing Correct?
