Head light/Wiper question
Old Jun 21, 2002 | 03:04 AM
rambler323's Avatar
rambler323
Default Head light/Wiper question
How much power is run from the switches to the vacuum system?
(Is that even how it works?)
Old Jun 22, 2002 | 01:21 AM
WATTAC's Avatar
WATTAC
Default Re: Head light/Wiper question (rambler323)
The headlight vacuum "switch" is actually a valve, so no electrical power is used to open and close it. You do that when you turn the lights on and off.
The wiper switch supplies a relatively small amount of power to a vacuum valve mounted on the tach. The power is probably about the same as goes to any other relay in the car, I'd guess (real guess) less than an amp.
Andy
