Rear Diff.
Old Jun 21, 2002 | 03:46 AM
Scudd's Avatar
Scudd
Default Rear Diff.
How would I know if the rear differential is bad or going bad in my 75 ?
Old Jun 21, 2002 | 03:59 AM
PrarieShark's Avatar
PrarieShark
From: The cure for the blues is eight cylinders roaring
Default Re: Rear Diff. (Scudd)
Im no expert but what makes you think you have a problem?
Old Jun 21, 2002 | 04:57 PM
75 Hot One's Avatar
75 Hot One
Default Re: Rear Diff. (Wightnite)
Unless you have a particular concern, I would leave it alone. There are different diagnostic procedures used for different problems including dismantling & examining for wear pattern on the teeth. Potential problems are: 1. noise signalling a bad bearing, 2. a clunk when accelerating or decelerating signalling wear, 3. end play on the side yokes signalling wear or damage on the C-clips holding the yokes in. Have to measure the last one. Other problem is oil leak signalling worn seal.
Old Jun 21, 2002 | 06:28 PM
gkull's Avatar
gkull
It depends on how many miles and how it's been used. I tell all my friends who pretty much baby their C-3 if they have 80-100K miles that they ought to pull the cover and inspect the cheap poopie GM yokes for end ware.
What happened to me at 50,000 miles was I started to hear bad noises coming out of the pumpkin. The yokes had worn away past the snap rings and the metal just ate the whole thing up. There is a $375 core charge and mine was so bad that it went in the dumpster. The cas was clear full of metal & oil mud
I was under the impression that Vettes were a performance car. Well they aren't built to really have to much fun in.
To Rear Diff.
