From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Originally Posted by BKbroiler
Then why did they put the battery on the driver's side?
Regarding the engine offset effect, let's do the math. Let's assume a BB engine and transmission weighs 700 pounds. If we move it one inch we have a weight/moment arm of 700 pounds times one-twelfth of a foot, equaling 58.3 foot pounds. A typical driver (lets say 190 pounds) sits about ten inches to the left of the vehicle centerline. That weight placement is 190 pounds times (10/12 of a foot), equaling 158.3 foot pounds. The offset driver has about two and a half times the effect of the offset engine.
(Disclaimer: Freshman statics class was decades ago. I welcome anyone doublechecking my work.)
Awwwwwww OK. Yes, Alan was right and to a lesser degree to allow space for the steering box.
Wrong, Wrong, Wrong!!! The REAL reason is to make it bloody near impossible to do a right hand drive conversion.
Up until about twelve years ago, the registration authorities MANDATED that ALL cars had to be RHD. Luckily, common sense prevailed and now we can fully register any LHD car or light truck that is more than 30 years old, up until a manufacturing date of January 1, 1989.
After that, ALL cars must be converted to RHD in order to be registered.
So late C4 owners and all C5 and C6 owners have to have their cars converted if they want them to be registered Down Under.
It's a cross we have to bear.
Regards from Down Under.
aussiejohn
Maybe y'all could get them to legislate you to the other side of the road like the rest of the world? You are already driving upside down.
The real reason for the engine offset in C3s is to compensate for the phase transluctance of the spurving bearings in the transmission. The capacitive duractance caused by the sinusoidal depleneration of the offset is the reason for the battery being on the driver's side. It's all very simple..........
It was a conspiracy plot between GM and Rockwell who made the fibreglass body panels. They knew that many owners would cut holes in their hoods to accommodate blowers, air cleaners, scoops etc etc but would not realize that the engine was offset to the right, and would ruin the hood by cutting the hole dead centre instead.
All the executives got big bonuses based on the sale of replacement hoods.
It is 1 and 1/4" off center to the passanger side. It was offset to provide more room on the drivers side for manual transmission to allow room for clutch pedal. Ran into the same question a few years back when I needed to cut an opening in my hood. Did extensive research and that is what I found out!
