All 'OEM Replacement' C3 Radiators are NOT created equal
Old Apr 28, 2013 | 10:23 AM
TedH's Avatar
TedH
Default All 'OEM Replacement' C3 Radiators are NOT created equal
I got a killer deal on a replacement radiator. Taking my radiator out of the car for the roller cam swap, I really tore the core up (it was stubborn coming out... surprised me as it came out much more easily the last time).
Well, I got a line on a replacement from Auto Zone. Price was right (under $200 delivered).
It arrived. Two things I saw right away:
The upper inlet is not all one diameter. It is small and then steps up to the dimension of the inlet on my modine (now out of business) radiator I got from Western Auto back before they became Autozone. Not sure how my OEM hose would stay put (it won't).
The top bar where the air dam seal should attach with two clips is not pre-drilled for the push-in clips.
I am considering having my radiator core replaced than to install this unit.
Old Apr 28, 2013 | 10:40 AM
Taijutsu's Avatar
Taijutsu
Default I hear you!
Ted: Years ago when I was upgrading my cooling system,
I had my rad recored from a 3 to a 4 locally.
I think it was about $200.
Not only that, but I had a **** added for draining.
That combined w/dual spals has been great.
I was next to a C-5 who asked me "How hot?
in a traffic jam. I told him 205*, he was 230*.
R
Old Apr 28, 2013 | 11:54 AM
jnealg's Avatar
jnealg
that 205/230 comparison is apples to oranges. My c4 LT-1 wont even turn the fans on until 228. thats how it is designed. If the c5 is anything like mine, 230 would be perfectly fine.
Old Apr 28, 2013 | 12:45 PM
augiedoggy's Avatar
augiedoggy
My old 84 was the same way (225-228) until I replaced the fan temp switch with one designed to come on at a cooler temp... I had a 180 stat installed.
Higher temps were for emissions purposes.
Old Apr 28, 2013 | 04:05 PM
jb78L-82's Avatar
jb78L-82
Higher temps for emissions was also the reason for the 78/79 L-82's running 225-230 routinely and for the cracked 882 head phenomenon. No emissions now, Dewitts radiator, aluminum Stewart Stage 2 water pump and 180 thermostat today and the car runs 175-180 all day.
To All 'OEM Replacement' C3 Radiators are NOT created equal
