Proper Big-Block Running Temp?
Old Apr 29, 2013 | 02:54 PM
TarheelBill's Avatar
TarheelBill
6th Gear
Default Proper Big-Block Running Temp?
Gotta '73, 454, with after market aluminum radiator/dual fans. Right now, both fans running full time. Temp gauge lays on 100 (doesn't move at all). Have a tech getting ready to 1) check gauge, and 2) rewire so that one fan runs when car is runiing, second one will kick in when the factory A/C is running. My basic question is what should I expect for the running temp of this 454 once I get the gauge working, and the fans rewired? 180? 210? Thanks for any input...
Old Apr 29, 2013 | 03:27 PM
diehrd's Avatar
diehrd
180 would be ideal but I would say you will be 190 to 210 and set the fans to run off a temp sensor and run them both not one until the A/C is on
Old Apr 29, 2013 | 05:01 PM
Mike Ward's Avatar
Mike Ward
'Normal', ie. when the car was new, was between the thermostat setting and about 210 or 220.
Old Apr 29, 2013 | 05:54 PM
dtamustang's Avatar
dtamustang
my 72 bb with factory a/c runs a very steady 180ish with the a/c off 190ish with it on. i'm running the o/e clutch and fan. had electric on there for a while but did not care for the temp fluctuations.
Old Apr 29, 2013 | 06:17 PM
flyeri's Avatar
flyeri
Mine runs around 180 on hot or cold days. It will sneak up a few degrees if I run it hard up through the gears, maybe 190, but drops back in less than 1 minute. No a/c with 5 speed.
Edit: Forgot to say Griffith radiator and stock fan
Old Apr 29, 2013 | 09:29 PM
Super6's Avatar
Super6
This is my experience also with aluminum radiator in Florida. Around 180F. Goes up after a long light, but as soon as the car is moving the temps drop immediately. Running stock fan.
Old Apr 29, 2013 | 11:01 PM
garygnu's Avatar
garygnu
make sure to bleed all the air out of your cooling system .I use a thermostat housing with a radiator cap on it ,it is the highest point of my cooling system.
Old Apr 30, 2013 | 10:58 PM
LS4 PILOT's Avatar
LS4 PILOT
my Ls4 generally runs 180 to 195 depending on ambient temps and how hard I have my foot in the gas.
the 73 and 74 cars 454/AC. cars had a extra spoiler extension under the nose to scoop up addition air. see the AIM
This addition as well as using all the foam seals to force the air through the radiator will help
my 454 engine temp runs every bit as cool as the same 74 350 I owned back in 1979. , both stock cooling systems.
To Proper Big-Block Running Temp?
