Blown Header Gasket
Old Apr 29, 2013 | 04:41 PM
MAXCO's Avatar
MAXCO
Default Blown Header Gasket
So this weekend I found out I have a blown header gasket...
Hedman Headers on a mainly stock L82 (1978)
How brutal of a job is it to change a header gasket? Can I do it without removing the headers completely out out of the engine bay? Basically just sliding old gasket out, new gasket in?
Old Apr 29, 2013 | 04:51 PM
DRIVESHAFT's Avatar
DRIVESHAFT
If you get lucky and the old gasket comes out easy, then you can do it without pulling the header.
If the current gaskets are the pressed paper type, you will probably have to pull the header so that you can scrape the old gasket material off of the sealing surface.
If you have to pull the header, it's worth while to lay a straight edge on the sealing surface to make sure its flat.
Old Apr 29, 2013 | 04:57 PM
Konkol1's Avatar
Konkol1
Get the soft aluminum ones. I can't remember who makes them since it was so long ago (12+ years) since I switched to that type I forgot.
Old Apr 29, 2013 | 05:12 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Remflex
Which side? Pass side with AC bracket is much more involved than driver side.
Old Apr 29, 2013 | 06:31 PM
ezobens's Avatar
ezobens
Originally Posted by DucatiDon
Remflex
I use them on all my cars / boats- Never had a leak!
Old Apr 30, 2013 | 12:47 PM
MAXCO's Avatar
MAXCO
Remflex
I've heard good things about Remflex.
It is the Passenger side, but the AC AC was removed years ago so hopefully it won't be too much of a Bee Sting to get out....
To Blown Header Gasket
