New Engine ordered
Old May 1, 2013 | 11:55 AM
Hop's 78's Avatar
Hop's 78
Default New Engine ordered
I came to the conclusion that it was time to do something about the tired old 350 with 118k and the occasional smoke cloud that would follow me. After considering pulling it for a rebuild, I determined time and $ would be better spent on a nice crate engine.
Well, I now have a 383 stage 2 ordered.
Let the fun begin!
Old May 1, 2013 | 12:22 PM
qwank's Avatar
qwank
awesome!! I'm sure you'll love it
Old May 1, 2013 | 12:24 PM
jackwabbit703's Avatar
jackwabbit703
Let the fun begin!
NICE!!
Make sure not to use synthetic oil until engine rings are fully seated. For my 406, I didn't go by the mileage for the engine break in period. I went by the engine oil consumption level as I was advised by the engine builder. Just check often to see if oil level dropped and does not decrease anymore.
Old Jun 9, 2013 | 09:22 AM
Hop's 78's Avatar
Hop's 78
Quick update:
Pulled the old engine last weekend. got the new dropped into place yesterday and will start hooking everything up today. With any luck I can hear it run later today
I have some pics if I can figure out how to post them.
Old Jun 9, 2013 | 01:22 PM
bluedawg's Avatar
bluedawg
Nice. Who built your engine.
Old Jun 9, 2013 | 01:54 PM
cv67's Avatar
cv67
St. Jude Donor '05
Youll love that 383. Increase in cubes makes it sound like it wouldnt be that big a difference but that extra stroke youll feel esp at WOT
Old Jun 9, 2013 | 09:14 PM
Hop's 78's Avatar
Hop's 78
www.westcoastengines.com
Old Jun 9, 2013 | 11:46 PM
cagotzmann's Avatar
cagotzmann
Let the fun begin!
Did you need to do any mod's to fit under the stock hood. I am also looking to update the stock 350 in my 1978. I have been looking at the ZZ4 GM Crate turn key package.
Old Jun 9, 2013 | 11:50 PM
bluedawg's Avatar
bluedawg
West coast seems legit.
Old Jun 10, 2013 | 10:15 AM
Hop's 78's Avatar
Hop's 78
Not quite done yet and haven't put the hood back on, but, so far everything is matched up perfectly.
Old Jun 11, 2013 | 05:55 AM
scottw's Avatar
scottw
Congrats.
Old Jun 11, 2013 | 07:22 AM
U17's Avatar
U17
Congrats !!! I went with the ZZ383...no break-in ect... All done at GM ... Did have to add a cowl induction rise in the hood.. Just finished the "Hot Rod Power Tour"... Never even opened the hood !!! (2500 miles)
Old Jun 11, 2013 | 07:37 AM
gdh's Avatar
gdh
Looks like a great engine, you will have a lot fun with it.
I have been considering going this route as well but maybe add a Fast EFI or other system + a T56. Looking fwd to reading your reviews.
Old Jun 11, 2013 | 08:15 AM
alswagg's Avatar
alswagg
Originally Posted by jackwabbit703
NICE!!
I always laugh at this. Every single engine we install immediatly from the get go, gets synthetic oil. These are brand new Vortec rotating assy's, most are ZZ4's. No issues, ever, not one for years. Many of our Marinized manufactures recommend this, Heck, Nearly all are now also using Synthetic oils from the start. Merc, Volvo, PCM, Indmar, Ilmore. ect. I know this can lead to a debate over oil and such, but here we go. Oh, and yes, we run at WOT nearly immediatly. Under 1hr of run time, and then up to 5,250 rpm while under load. Varying, from 3k to 5 k. We tell our customers, run it like you would any other time. These motors are nearly bullet proof.
Al
Old Jun 11, 2013 | 08:39 AM
Hop's 78's Avatar
Hop's 78
http://forums.corvetteforum.com/memb...ine-34593.html
There's the link to my "new engine" album.
You may notice if you look carefully that we used one of those nice engine lift brackets that bolt to the manifold in place of the carb. Worked great, however, you will notice in the last couple pics it looks flat. The piece the chain hooks through snapped off! Luckily we were already resting on the motor mounts and simply working to re-position at the time. Only 5 minutes earlier and the engine was 4ft in the air while we lifted it up over the fender....that, would have been catastrophic!!!
Old Jun 18, 2013 | 11:07 AM
Hop's 78's Avatar
Hop's 78
Ok, my schedule's been tight trying to find time to finish this. With any luck she will be fired up tonight!
Old Jun 19, 2013 | 08:33 AM
Hop's 78's Avatar
Hop's 78
IT LIVES!
Fired right up within seconds last night....sounds like a nasty ****!
Got a couple things to button up tonight then I can take her out for a test drive.
To New Engine ordered
Old Jun 19, 2013 | 02:22 PM
78SilverCam's Avatar
78SilverCam
You had to raise the hood with a 383? Is this common for all 383 crates?
Old Jun 19, 2013 | 02:39 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Only depending on the induction system on top. Tall manifold and carb/air cleaner combo means limited to no clearance. It is the same size otherwise as any small block.
Old Jun 20, 2013 | 08:56 AM
Hop's 78's Avatar
Hop's 78
Holy CRAP!!!!
Took it out last night for the 1st drive. Gave it a quick wash and went to a cruise night with it....and left the hood off. The thing was incredible!!!
I was concerned when I put the air cleaner on that it sat too high even though in my mind I knew the engine and manifold heights were supposed to be the same, it just "looked" high. After we got back from the car cruise we put it on and it fits. Would have sucked since a good friend painted the underside for me with a punisher skull.
