headlights now come down but not back up
Before this, I just manually raised and closed the headlights, but now I can only raise them when the manual override switch is pulled. Then I can push the switch and the lights will go down.
I don't have a vacuum pump so before I try to get one and start troubleshooting can anyone suggest a solution to the current problem? Actuator seals? Valves/filters? It feels like I'm so close and that it could be an easy fix. Thanks.
The vacuum pump is the best way to diagnose your system, one component at a time. However, you don't have one, so the next step is to borrow one. The Autozone stores in my area loan these out with a deposit which you get back when it's returned. If you want another way to test the major components, follow along.....
I think I know what your problem is, but first I suggest you start checking in this order. You know how to raise and lower the lights manually, so that's what we will focus on to start. NOTE; All tests are with the engine off.
Pull the vacuum hoses off the actuators front and back. Move the headlights up and down from full down to full lock. Be careful to support with it one hand while the other does the work. Don't slam or get body parts caught anywhere as the lights should move rather freely. Now, with the lights in the down position, plug the back (toward the back of car) vacuum outlet with a small piece of plugged tubing. Try to raise the headlight. If you can with the same effort as not plugged, the actuator is junk. If you cannot raise it, remove the plug and raise the headlight. Repeat for each side.
Put the plugged tube on the front of the actuator to seal that side, and do the same test, only try to lower the headlight. You should not be able lower it. If you can, your actuator may be able to be repaired with a new front seal. You can find them at Willcox. You will have to remove the actuator to do this. Repeat for each side.
Next, test the relays. Disconnect the vacuum hoses and find a clean two foot section to blow through. Connect one end to the center outlet of the relay. Plug the bottom outlet with your finger, and try to blow through the hose. You should not be able to do it.
I have found almost all headlight problems can be diagnosed this way. Try it and report back, we'll go from there.
