Which Heater Core Do I Use?
Old May 2, 2013 | 08:20 PM
76Vett's Avatar
76Vett
Default Which Heater Core Do I Use?
I have a late 76 and need to replace the leaking Heater Core. I'm removing all the AC stuff as I've never used it in the 2 years I've owned this car. I found out there are two heater cores, one for an AC car and one without AC - which one will I need for mine?
Old May 6, 2013 | 03:57 PM
MelWff's Avatar
MelWff
Unless you are removing the evaporator case, you have to stick with the a/c core because of the shape of the inlet and outlet pipes.
