What the *%&^ are "AN" sizes?
Old Jun 21, 2002 | 05:38 PM
Shrike's Avatar
Shrike
Default What the *%&^ are "AN" sizes?
I am looking at hoses and fittings and I don't know what, for instance, a -03 AN fitting is. What size is it in inches (roughly)? Is there a chart somewhere with various sizes and equivalents? Thanks for any help.
Old Jun 21, 2002 | 05:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: What the *%&^ are "AN" sizes? (Shrike)
Found this when I was looking for my new fogger system :D
http://www.holley.com/HiOctn/ProdLin...echcorner.html
Hope it helps
Old Jun 21, 2002 | 06:07 PM
Larry B.'s Avatar
Larry B.
"AN" is Army Navy stardard. This is a common light aviation spec.Typically the dash (-) is in 1/16"incremants, so - 03 would be 3/16" diameter. That's not always the case though. Find info on "an", "nas"(natiolal aircraft standard), and "ms" (military standard. There may be some help on the web.
Old Jun 21, 2002 | 06:18 PM
Shrike's Avatar
Shrike
Default Re: What the *%&^ are "AN" sizes? (silvervetteman)
MotorHead- Thanks for the link :)
silvervetteman- I tried searching the net, but the search engines read "AN" as "an" and basically ignore it. :(
Old Jun 22, 2002 | 01:42 AM
tictocdok's Avatar
tictocdok
use only AN fittings with AN fittings. I found you could match up a couple common plumbing fittings, and the AN would connect to it, but there is a difference in taper of the flare and you won't get a seal.
I think the AN fittings had a deeper flare angle to give more of a surface to mate to and thus a safer connection.
To What the *%&^ are "AN" sizes?
