75 stingray possible rear end problems?
Old May 5, 2013 | 07:08 PM
jskenter's Avatar
jskenter
Cruising
Default 75 stingray possible rear end problems?
When I drive my car, it sounds as if I am dragging something with an occasional "clunk, clunk,clunk" I checked the U joint and that is fine. And I just had the exhaust done because it was not secured right and used to make a similar noise. I thought it would stop after that but it hasnt. Anyone have any idea on what it could be?
Old May 5, 2013 | 07:12 PM
4 speed's Avatar
4 speed
the dragging noise could be a bad brake pad, eith worn or I've seen the pads come "unglued" . I'm not sure about the rear my self.
Old May 5, 2013 | 10:20 PM
wombvette's Avatar
wombvette
More than likely posi clutches. Especially if it does it more when hot. Change the fluid/ additive, and check for the common yoke wear that is prominent in `75-76.
Old May 6, 2013 | 03:16 PM
dochorsepower's Avatar
dochorsepower
Clunk and drag could be separate problems. Add some posi fluid to the differential for the clunk, then check your rear wheel bearings.
To 75 stingray possible rear end problems?
