Idle Speed
Old May 6, 2013 | 06:47 PM
bravados's Avatar
bravados
Default Idle Speed
Once warm my vette seems to be ok sitting in park but once in drive I find myself having to put a little gas to keep ticking over. This makes going to reverse annoying as having to have a little gas and foot on brake means reverse is abit of a clunk/bang when selecting. Would I need to be adjusting my idle speed here?
Cheers guys
Old May 6, 2013 | 07:39 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Raise your in gear idle to where it runs without dying. Usually between 600 and 800.
If you have a wild cam, 1k up may be necessary.
Year and motor help.....
Old May 7, 2013 | 01:12 AM
mrmagrath's Avatar
mrmagrath
If you have a Q-Jet, the idle screw is on the drivers side of the carb facing forward. Hard to miss! Screw it clockwise half a turn when warm and check to see if the problem's still there. Repeat if necessary.
Old May 7, 2013 | 02:50 AM
bravados's Avatar
bravados
Ahh its a 74 small block auto. So turn the idle screw in clockwise on q-jet half a turn. Thanks guys.
Old May 7, 2013 | 09:10 AM
mk's78's Avatar
mk's78
Very Interesting post.....Could I get a suggested "in-gear" idle rpm for my 78/stock 350/auto?????.......as in what would be too high vs too low????????????
Seems like the 525-550 is just too low...............(as set by my old school vette tech).....according to his version of GM tech data.......
mikes 78SA
To Idle Speed
