Trying to find replacement part
One of the tests that failed was for the Head Lamp Actuators. The first phase that tested the internal diaphragm passed, the second test for internal diaphragm and real sealing grommet failed. The guide says to replace the grommet- here lies my question....what grommet?
I've looked on Ecklers and Zips, neither have a real sealing grommet. Is there another name for this part?
Thank you!
FUNCTION: The headlamp actuators open or close the headlamp doors. More specifically, the green hose opens the headlamp doors and red closes them.
TROUBLESHOOTING: Perform the following two steps in order.
1. With headlamps in the closed position, disconnect the large red hose and attach the vacuum pump. If the vacuum pressure holds, the internal diaphragm is good. If the vacuum pressure drops, the internal diaphragm is leaking and the actuator must be replaced.
2. With the headlamps in the open and locked position (if the headlamps will not open normally, try opening them manually by pushing them up from the front underside of the vehicle), disconnect the large green hose and attach the vacuum pump. If vacuum pressure holds, the internal diaphragm and rear sealing grommet are both good. If the vacuum pressure drops, replace the grommet. NOTE: If you do not open the headlamps prior to this test, applying vacuum to the port should slowly open the headlamps until they are completely open. At this point this port should hold a vacuum.
The HDL-224 is the rod seal by itself, the HDL-291 is the kit with the boot and retainer.
I remember you calling, I think this is what you are looking for.
Tom @ Zip
1-800-962-9632 ext 240
Zip Corvette Parts and Accessories - Corvettes Are All We Do!
Selling Quality Corvette Parts & Accessories Since 1977
Corvette Parts Catalogs | Subscribe to our newsletter
Corvette Tech Articles | Corvette Parts Blog
Thank you!
Is there a way to replace the seal without removing the actuator from the car? Thanks
