1980 how to power window test ?
Old May 9, 2013 | 08:36 PM
Jeffsvettes's Avatar
Jeffsvettes
Default 1980 how to power window test ?
Is there an easy way to test if the power windows work on a set of doors that are not installed on a car. The doors came off an 80. Can I just put 12 volts to 2 of the wires and if so which ones.
Thanks in advance.
Jeff
Old May 9, 2013 | 09:43 PM
Peterbuilt's Avatar
Peterbuilt
Apply a ground to the motor case and 12 volts + to one terminal and the window will go up.
Apply 12 volts + to the other terminal and the window will go down.
Old May 9, 2013 | 09:51 PM
Jeffsvettes
Thanks I'll try them tomorrow
Jeff
To 1980 how to power window test ?
