Caliper help Please!
Old May 9, 2013 | 10:56 PM
Rowarrior's Avatar
Rowarrior
Default Caliper help Please!
Hi all,
I had to replace the metal brake line that feeds my rear left caliper. I understand I have to bleed that caliper.
For what I have been reading I have to bleed the inner half first and then the outer half. Correct?
Apparently each half has 1 bleeding nipple, but my calipers have 2 bleeding nipples on the outer half and 1 on the inner half.
How to I proceed? I suppose I still should start with the inner half(as it only has 1 nipple) and then with the outer half, but which of the 2 nipples in the outer half should I bleed first?
Thank you in advance!
Old May 9, 2013 | 11:09 PM
redvetracr's Avatar
redvetracr
you only bleed the bleeders that face forward, the rearward one should be a plug but you don`t need to concern yourself with it.
Old May 10, 2013 | 12:39 AM
BOOT77's Avatar
BOOT77
I bought two new calipers last fall and replaced the metal and flex rear lines on both sides. One had the plug other had the bleeder, I bought a bleeder for the plug one and just started farthest in flow and wokred my way toward the line.
Old May 10, 2013 | 01:37 PM
my 76 ray's Avatar
my 76 ray
The air will always be at the top. There is no need to bleed from the bottom.
Old May 10, 2013 | 01:51 PM
BOOT77's Avatar
BOOT77
Even when new and bone dry?
Old May 10, 2013 | 05:10 PM
my 76 ray's Avatar
my 76 ray
Yep.
Old May 10, 2013 | 05:41 PM
BOOT77's Avatar
BOOT77
Pretty sure I gave that a shot and ended up bleed all started with farthest and got a lil air from each. Also think I read on here to bleed em like that.
Old May 11, 2013 | 11:22 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
The factory plugged the bottom hole. Rebuilders add bleeders to the previously plugged ones. I did a gravity bleed when I did mine a few weeks ago. Work great now. Simple.
Old May 12, 2013 | 09:23 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by CaseyJones
...The factory plugged the bottom hole...
Correct. Outer caliper halves can be swapped from side to side. The bleeder is always at the top; bottom port is always plugged.
Old May 12, 2013 | 10:44 AM
redvetracr's Avatar
redvetracr
rear outer caliper halves are NOT the same and can NOT be swapped, they only have one fluid transfer hole...
Old May 12, 2013 | 03:02 PM
Rowarrior's Avatar
Rowarrior
thanks guys for the help!!!
So! I was just going to proceed to bleed the caliper when I noticed the pin pad was GONE!
the caliper is "almost" in the right position position, it is just a little higher of where it should be. the holes on the calipers are higher than the holes on the wheel assembly. I got a new pad pin but I how do I get them to align now? do I have to disconnect the caliper to reduce the pressure on the disc ? or do u ise a rubber hammer? (that i sort of did but it did not work)
see picture. help? thanks!
caliper | Flickr - Photo Sharing!
To Caliper help Please!
