Tool dimensions
Old May 10, 2013 | 08:50 AM
shrek66's Avatar
shrek66
Default Tool dimensions
In my service manual for a 74 Corvette, there is a tool used to keep the lower control arm from bending when pressing out the bushings. It is basically a pipe with a slot cut in it to allow a tech to put it between the bushings and over the A arm control shaft.
Does anyone have those dimensions?
Old May 10, 2013 | 09:26 AM
wombvette's Avatar
wombvette
I doubt you will find anyone that has ever seen or used one. We all use a different method. The tool may work with good parts, but if that thing is rusted and the bushing is stuck, I doubt it would work.
Old May 10, 2013 | 09:56 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Here ya go!
http://mycorvetterestoration.com/196..._arm_shaft.php
Old May 10, 2013 | 10:05 AM
shrek66's Avatar
shrek66
I understand what you are saying. I am trying to replicate the tools the service manual lists. The arms I have now are not in terrible condition. The upper control arms were very easy removing them; the lower control arm being larger and having a differen angle is what is making it difficult for me to press out the bushing. I am making a tool righ now which will help, I may be able to get away with just that. I wonder what happened to all the old tools listed in the service manual. I have found a few listed on ebay but many are not to be found.
Old May 10, 2013 | 11:13 AM
20mercury's Avatar
20mercury
Default Ditto here.
Originally Posted by resdoggie
This is what I did. This homemade tool is referenced in other info too. I also put some metal spacers in between the 2 bushing holes on each side of the lower control arms too to keep the 2 bushing holes on each side from bending together.
Old May 10, 2013 | 11:25 AM
shrek66's Avatar
shrek66
resdoggie, 20mercury,
Thank you, that is what I am looking for.
I appreciate the help.
Old May 10, 2013 | 12:42 PM
Tom454's Avatar
Tom454
I have the actual GM Service tools... one for the upper, 3 pieces for the lower. Let me know if you're still interested. The lower tool has two c shaped inserts to keep the inner & outer eyes from collapsing under compression. The shafts should rotate freely by hand after the new bushings are installed.
Edit: there's also a plate with a jig welded to it as part of the set.
To Tool dimensions
