Short or long water pump
Old May 12, 2013 | 11:08 AM
redwhitekat's Avatar
redwhitekat
Default Short or long water pump
I've been looking at buying a alluminum pulley kit online but most say its for use with a long water pump
Mine is stock any idea what's its considered long or short ?
Old May 12, 2013 | 11:10 AM
qwank's Avatar
qwank
what year car? most likely it's short
Old May 12, 2013 | 11:11 AM
redwhitekat
It's a 74 l82
Old May 12, 2013 | 08:30 PM
glen242's Avatar
glen242
I believe GM had a long pump, short pump, and a Corvette pump that was between the two.
Old May 12, 2013 | 09:27 PM
redwhitekat
Well mine is against the timing cover so my guess its prob a short
Old May 12, 2013 | 09:55 PM
Mooser's Avatar
Mooser
Mooser
Old May 12, 2013 | 09:59 PM
redwhitekat
Thanks for the info
Old May 13, 2013 | 12:08 AM
donyue's Avatar
donyue
Hi redwhitekat,
If your car is a L-82 then it should be a short water pump. My 77 L-82 had the short water pump.
Also, depending on the type of aluminum pulleys you are looking for the following company seems to make them specifically for our cars, as long as you are still going with V-belt pulleys and not serpentine. Good prices, and made in the USA.
http://www.cvfracing.com/corvette-pulleys-s/94.htm
Old May 13, 2013 | 07:26 PM
PeteZO6's Avatar
PeteZO6
All C3 Corvettes use a short water pump, BUT, somewhere around '69 to '71 the short pump got ~3/16" longer. Still a short pump, but you have to pay attention to your year model.
Pete
To Short or long water pump
