73 Brake Bleeders
Old May 12, 2013 | 11:27 AM
patriotcommercial's Avatar
patriotcommercial
Default 73 Brake Bleeders
I an putting my rear calibers together. What is the positions of the bleeders and the positions of the plugs ?
Old May 12, 2013 | 11:57 AM
gcusmano74's Avatar
gcusmano74
Bleeders are high, plugs are low.
Old May 12, 2013 | 04:13 PM
my 76 ray's Avatar
my 76 ray
If you are putting the two halves together, the brake line input will be on the piece that has the mounting tabs. It goes toward the rear of the car on the inside of the rotor. The plug will be on the outside of the rotor to the rear of the car. Bothe bleeder screws will be in the holes toward the front of the car. When mounted on the car the bleeders will be higher than the plug and brake line input.
Old May 12, 2013 | 05:07 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I would install stainless bleeders.
To 73 Brake Bleeders
