Brakes on 1975 c3
Old May 13, 2013 | 12:57 AM
Darkdude's Avatar
Darkdude
5th Gear
Default Please help...brakes. 75... C3
Hello, this is my first ever forum involvement as I'm at the end of my rope. I hope someone can help me. I have just added new...master cylinder, brake lines, proportioning valve, calipers, pads. In other words everything is new from the mc to the rear. I can't get fluid to the rear, Either axle. I tried...gravity bleed, 2 person bleed, power bleed (using compressor), I even tried to bypass the proportioning valve and still no fluid to the rear. I ran the air hose thru to blow out line(dirt). I don't know what else to do. Could it be the booster? That's the only thing I haven't tried and i didn't want to throw away more unnecessary money. Any help would be greatly appreciated. Thanks in advance.
Old May 13, 2013 | 03:05 AM
rcread's Avatar
rcread
Did you bench bleed the new master cylinder?
Old May 13, 2013 | 11:51 AM
my 76 ray's Avatar
my 76 ray
The booster has nothing to do with the hydraulic system. Save your money.
Old May 13, 2013 | 11:59 AM
Darkdude's Avatar
Darkdude
5th Gear
Yes, I did
Old May 13, 2013 | 12:02 PM
Jig A Low's Avatar
Jig A Low
do you get air through the lines to the calipers? if so, there is no reason the fluid won't go through either.
Old May 13, 2013 | 12:04 PM
my 76 ray's Avatar
my 76 ray
Are you getting fluid out of the rear port on the master cylinder? The only thing I can think of is that somehow when you intalled it the rear piston is already depressed past the hole that allows the fluid to enter the piston. No amount of bleeding will work if fluid can't get into the piston. If you take the cover off the master cylinder and press the brake pedal, you should see the fluid move at the hole where it goes from the reservoir to the piston. That will at least tell you that the piston is moving.
Old May 13, 2013 | 03:46 PM
Darkdude's Avatar
Darkdude
5th Gear
I thought I was getting a decent amount of fluid to the rear when I used the pneumatic bleeder, but when I started the car and put it in gear(while it was on the lift) the rear tires would not stop when the pedal was pushed.
Old May 13, 2013 | 04:16 PM
Peterbuilt's Avatar
Peterbuilt
I'll guess that the master cylinder is bad.
You can re-bleed it on the car and see if there is an equal amount of fluid moving on each pump.
If not then leave the front bleed connected and plug the rear port.
If the pedal is not rock hard then the M/C is bad.
Old May 13, 2013 | 04:25 PM
my 76 ray's Avatar
my 76 ray
So you are getting fluid to the rear!!! Your original post said "I can't get fluid to the rear, Either axle. I tried...gravity bleed, 2 person bleed, power bleed (using compressor), I even tried to bypass the proportioning valve and still no fluid to the rear." If you want to get good advice then you have to give accurate information.
Since everything is all new it's possible that your pistons were back in the bore and need to be pushed up against the pads. Try slowly pumping the brake pedal and watching the level of fluid in the master cylinder. If it is getting lower then you either have a leak somewhere or the pistons are being pushed up against the pads. Don't let the reservoir in the master cylinder get empty or you will have to start over with bench bleeding.
Putting the car in gear with the rear suspension hanging isn't a good idea. The u-joints in the half shafts can bind.
Old May 13, 2013 | 04:32 PM
76stingracer's Avatar
76stingracer
Check the adjustable push-rod that is in the brake booster that pushes on the master cylinder piston. Measure the distance on the master cylinder to the seat on the piston that it pushes on and then measure the rod and adjust. Check a manual for the correct clearance distance.
Old May 13, 2013 | 04:42 PM
Darkdude's Avatar
Darkdude
5th Gear
I'll see what I can do.
Old May 13, 2013 | 04:44 PM
Darkdude's Avatar
Darkdude
5th Gear
Well I wrote in the first post that there was nothing because I thought that the very little I was getting and the wheels not stopping was equivalent to nothing.
Old May 13, 2013 | 05:17 PM
Peterbuilt's Avatar
Peterbuilt
Good point!
Some of the M/C have a divot and some have a deeper hole and they don't work if swapped out.
To Brakes on 1975 c3
