A/C question
here's the deal, doing a body off resto-mod on my '81, during it I'm replacing the entire A/c system. the only part that will be re-used is the small liquid line which will be cleaned out really well.
I already have the new R-4 compressor, hose set, dryer, evaporator, condensor and orifice tube.
question #1: which refrigerant should I go with, I don't think R-12 is a viable option due to expense. I've read about "hot shot" but haven't done much research on it.
question #2: do I need to change the o-rings if I go with the 134A? the ones I have now came on the replacement parts that I'm sure were designed for R-12.
question #3: can I use the same orifice tube that was designed for R-12 or do I need to get something different.
I've already removed and resealed the housings (engine bay and interior) with all new gaskets/sealants.
thanks in advance.
