door adjustment for 81
Old May 14, 2013 | 08:07 AM
81 vette vent's Avatar
81 vette vent
Default door adjustment for 81
My door sticks out a little at the bottom. I noticed the shims at the bottom hinge. Are the shims slotted so I can just loosen the bolts and pull one out or do I need to remove the bolts completely to remove a shim?
What causes this over time? I was told years ago that fiberglass just moves over time. Is this true? The car has never been in any fender bender and I'm sure it didn't leave the showroom like this. Any ideas?
P.S. the hinges are new. I just changed them. The door was like this before I started and I was hoping the hinge pin and bushing would close the gap up a little.
Old May 14, 2013 | 08:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by 81 vette vent
...My door sticks out a little at the bottom. I noticed the shims at the bottom hinge. Are the shims slotted so I can just loosen the bolts and pull one out...
No.
...or do I need to remove the bolts completely to remove a shim?...
Yes.
...I was told years ago that fiberglass just moves over time. Is this true?...
No.
Are you sure your problem is a shim?
Post a pic.
Old May 14, 2013 | 10:10 AM
Jig A Low's Avatar
Jig A Low
the shims have holes for two of the bolts and slots for the other two. IRC the upper two have the holes and the bottom two are slotted.
as for what causes it, if you have new hinges then you can rule out the bushings and hinge pin. I think I would take a close look at the frame, I'll bet you won't like what you find.
Old May 14, 2013 | 12:14 PM
81 vette vent
My frame is in great shape. I bought it from a guy that keep it in his garage for the last 20 years. I inspected all Thatcher I bought it about 2 months ago. My buddy is a body man and he said the car has never been in any accidents. He told me it may have came from the factory like that. He has worked on 30 or so vetted over the years and he said many of them didn't line up good. I tried sending a picture from my phone but I can't figure it out.
Old May 14, 2013 | 01:04 PM
Jig A Low's Avatar
Jig A Low
as long as you're sure the frame is good, that's about all I can come up with other than maybe someone messed with the hinges before you got it and didn't get it back in place.
I doubt it came from the factory that way, I can't imagine Chevy selling a high dollar (at the time) sports car that wasn't right.-----WELL OK, maybe one or two but not all of them.
Old May 14, 2013 | 01:49 PM
81 vette vent
Thats funny!
I think guy did try to adjust at one time. He made a comment that made he stop for a second when he said it. He said He said, "I tried adjusting the doors to make them fit better a few years ago." The passinger side saged a little so I assumed he was talking about that. I knew as soon as I saw it that the hinge bushings were no good on that side. I replaced them and it looks very good. He may have played with something on the direver's side because the bushing on the driver's side was better than the one on the other side. I couldn't figure it out. Wouldn't the drivers side be worste? Anyway, I will try to take a shim out and see what happens. I am still trying to send pictures. Hopefully I can make this thing work.
Old May 14, 2013 | 03:03 PM
hugie82's Avatar
hugie82
I'm NOT a body guy but I've never seen shims used on door hinges except in cases of frame damage
. Are you sure that door didn't take a bad hit?
Old May 14, 2013 | 03:33 PM
81 vette vent
hugie
You may want to take a look inside your door jams where the hinges mount to the frame. GM used shims to adjust your door depth to the body. These cars had no other way to adjust the doors to the body depth wise. All of them used shims just as they use shims to adjust the trailing arms.
Old May 14, 2013 | 04:32 PM
81 vette vent
I put the pictures on my profile page in an album.
To door adjustment for 81
