Motorhead,
Those BFG 295's look TUFF on your car. I think I'm going to get me a set. So, you have 295 50's on the rear, and 265, 50's on the front? That tire combo has just the right stance to it. :yesnod: Let me burn up my 255's, and I'll get a set of those.
Maybe if I saw it from the front corner I might change my mind.
In my experience, you generally only get to see Wayne's car from behind!
The 295s at the back are way cool. They do, however, look like they're ready to friggin burst off the rims. I advise women and small children not to stand too close ....
it's true wayne...it looks great when you are driving behind you...why don't you ride with mark and i will drive your car in front and you can check out the view....i still have not heard my car pulling away from me with the baffles in.... :D
And I don't! Too big, makes the rear end stick up too high.
usually you would be right with wider tires making the rear looked jacked up, but with a 50 sereis tires, they are actually shorter than 255/60, even with 295/50's......27.0 vs. 26.6
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Re: MotorHead's Tires are SWEEEET (1bad69)
We will do that I have always wanted to hear what my car sounds like just have to trust someone to drive it right
WTF is this guy talking about:confused:
I have the exact same combo and the car is actually lower than before.
The O.D. of the stock 255/60-15 is 27.1" and for the 265/50-15 is 25.5" and 26.7 for the 295/50-15.
If you go wider, it does make a car look jacked up. BUT, If you go wider AND shorter, like MotorHead did, it looks great. 295/60/15's will look alot taller than 255/60/15's, you adjust that "jacked up" look by making the sidewall shorter (50) to even it out.
Actually, I think the 295'-50's would look better. Because the aspect ratio of the 295-50, would be around the same actual height of the 255-60. :yesnod: 295'60 would probably be taller than 255-60 :crazy:
Re: MotorHead's Tires are SWEEEET (74VETTE)
Motorhead....how did you get those bad butt tires to fit in the back anyway??
You have to do something with the e brake bracket either move it or grind it down, as all years are slightly different it's a good idea to test fit first as I have very little room in some places
