I'm leaking blinker fluid!
May 15, 2013 | 03:04 PM
Made you look!
May 15, 2013 | 03:18 PM
was wondering if you are running a blinker fluid filter?
May 15, 2013 | 04:11 PM
Quote:
Originally Posted by
billcarson
Nah, I think the modulator O rings are leaking
May 15, 2013 | 05:12 PM
Have you checked your flux capacitor lately?
Scott
May 15, 2013 | 07:04 PM
You need to pull your horn button and jam a screwdriver as far as you can push really hard. And if the fluid is touching the end of the screwdriver you're having worst problems then I can help you with.
May 15, 2013 | 07:10 PM
I think my air filter is leaking too.
May 15, 2013 | 07:29 PM
genuine1980
You mean it won't hold air anymore? Geez, that's not good at all! Speaking of air, that reminds me, it's getting to be time to let all the winter air out your tires, and replace it with summer air.
Scott
May 15, 2013 | 07:39 PM
I'm thinking about installing a speedometer cable ratio reducer, to get my speedometer to tell the correct MPH. Hah! Jokes on you, speedometer cable ratio reducers actually exist!
Hey, if you like techno-gibberish, you'll die laughing when you watch this:
Scott
May 15, 2013 | 08:11 PM
"no wait"!"the moderators will put a stop to this".
May 15, 2013 | 09:27 PM
follow your draft line I bet its full of A1R.
May 15, 2013 | 11:30 PM
Thanks for the laughs, Scottyp99... you guys crack me up. BillCarson always has the best photos to go with any post.
What's next? Muffler bearings vibrating badly?
May 15, 2013 | 11:41 PM
It's more likely halogen leaking from the headlight when they're closed...
May 16, 2013 | 02:00 AM
I'm so confused! I lost my 710 somewhere and need a new one.
May 16, 2013 | 11:28 AM
Bagmup
What does it do when they're open?
May 16, 2013 | 11:31 AM
Why do my tires only go flat on the bottom ?????
May 16, 2013 | 11:32 AM
oldsarge
It's an atmospheric pressure thing, you need to drive faster to get more air under the car
May 16, 2013 | 12:46 PM
If there were ever a car that could leak blinker fluid, the Corvette would be that car.
May 16, 2013 | 12:50 PM
Crash80
May 17, 2013 | 12:26 AM
Navigator
how is the beep charge holding out?
May 17, 2013 | 02:28 AM
AirborneSilva
ok but what happens at 120mph?
