What emissions stuff were put on corvettes and what do they do?
what emissions junk did they slap on corvettes(and other cars as well)and what do they do? Thanks
Re: What emissions stuff were put on corvettes and what do they do? (garagedweller2)
EGR -- Exhaust Gas Recirculation (self-explanatory)
AIR pump -- belt-driven pump that forced fresh air into exhaust ports
PCV -- Positive Crankcase Recirculation (not a bad thing)
EFE -- vapor containment system (I think)
Catalytic converter -- they were AWFUL in the '70s!
That's about all I can think of for now...
Re: What emissions stuff were put on corvettes and what do they do? (page62)
Expanding a little....
*Sends a portion of the exhaust gasses back into the engine's intake for another go-round. I don't recall the exact science behind it, but it alters the intake mixture (obviously) and helps reduce emissions.
*By puming fresh Oxygen (air) into the exhaust, you provide additional Oxygen for the bad compounds in the exhaust to react with to form GOOD things.
*Take the volatile fumes from inside of the engine and send them through the carb to be burnt. Perviouusly, those emissions were just allowed to go out into the air.
*brain fart. Can't remember
*Uses prescious and semi-prescious metals as catalysts (forces a reaction to happen faster) in order to convert BAD exhaust gasses into GOOD exhaust gasses.
Converts Oxides of Nitrogen (NOx) into Nitrogen and Oxygen
Converts Carbon Monoxide (CO) into Carbon DI-oxide (CO2)
Converts Hydrocarbons (HxCx) into Water and Carbon Dioxide
Have you had chemestry yet? When you do, ask your teacher if they don't bring it up. You might want to check out Catalytic Converters at http://www.howstuffworks.com
Dave
Dave
Re: What emissions stuff were put on corvettes and what do they do? (ddecart)
EFE - Early Fuel Evaporation which is the new name for the heat riser valve. Forces warm/hot air back up the system at start up to help the car warm up faster.
An over engineered brain fart.
what emissions junk did they slap on corvettes(and other cars as well) TOO MANY! and what do they do? IRRITATE ME!
Piece :cheers:
It took nearly 50 years for the engineers to figger out how to get an internal combustion engine to run right, then along came the smog *****....and that set back the program about 30 years right there....
the only saving grace to the internal combustion engine has been electronics, the issue of proper fuel burning under widely varying circumstances can only be adequately addressed by computers.....not by building mechanical kludge on top of mechanical kludge.....
A carb by it's very nature is one kludge on top of another, the ability of any mechanical device to run a gasoline engine properly is severely limited at best, and woefully inadequate at worst....the issues involved are just too great for simple solutions....
I would spend more time learning electronics and computers and basic engine theory....library is full of books on the topics....learning the old tyme methods of carb and ignition, allthough cute and quaint is not the useful information needed for the future....in other words, quit wasting time with basically useless information....
I don't mean to be hard or bitter sounding, but in fact, them's the facts....
GENE :cool: :cool: :cool: :D :D
The mess is the fault of :jester Congress who passed laws that were unknown how to meet. Despite comments from time to time by some who should know better all C3 had controls. GM threatened to stop making cars. The cars were so loaded w/ controls by 73-4 that new cars were having trouble meeting GM driveability stds.! So GM wanted the converters ....
Add TCS to the list.
Carbs are not near as bad as Gene's post could lead you to believe. There is some truth in it. Since Gene likes gas milage, Jag XKE 4.2 3 carbs 18 mpg, Lotus Elan said to get 30 mpg at 100 mph, Chevy 350 @ steady low speed w/ Q-J said to get about 30 mpg...
HP is no problem w/ carbs. I do find it a little funny that some of us :cool: are still running carbs.
:cool:
[Modified by Ganey, 7:59 PM 6/23/2002]
:cool:
Re: What emissions stuff were put on corvettes and what do they do? (Ganey)
Ganey is right about the 73 and 74 cars. Mine had all sorts of hesitations and little driveability glitches when I first got it, this was my fist carberated car so I figured I just wasn't used to it. After about 2 weeks I got the power itch again and started de-smogging it. It drives so much better after that it was like night and day especially when the distributor was recurved. Its come a long way since then but I'd have a hard time putting it all back on to go back to the little glitches again.
:cheers:
Pat Kunz
:cheers:
Pat Kunz
Re: What emissions stuff were put on corvettes and what do they do? (73 LS-4)
Hey Guys, I Just finished taking my 75 back to smog stock. I've found that it runs better( I sould say more pleasnt, and if I'd fixed "bubba's" mistakes it probablly would have been a Great Running car). I know it doesn't have the power it's capable of having but for now the State of California dictates what I do if I want to drive it on a daily basis. It is a pain to get it all working together so as to get rid of the "gitches" in operation. It drive nice and crisp. Fun Daily driver and smog legal in CA. 2005 I Bring back the Power If all goes well with the present legislation. Until then, I'm concentrating on suspension and looks.
Re: What emissions stuff were put on corvettes and what do they do? (Viking88)
Oh my God! Someone with a stock configuration like mine. Bless you! All kidding aside, they do run very well when all the systems are in sync.
Re: What emissions stuff were put on corvettes and what do they do? (paul79)
They also had TCS = Thermal Controlled Spark in 1970. It's a vac advance limiter gizmo. ~Juliet
Re: What emissions stuff were put on corvettes and what do they do? (Juliet)
Juliet,
Do not see you around C3 much these days! Nice to see a post from you. And I learned what a TCS is: a big bonus. Thanks for that.
Try Transmission Control Spark, another :reddevil
If they had put in enough cam, could have skipped the egr.
:cool:
