vacuum jumping
Old May 18, 2013 | 02:58 PM
palazzopl's Avatar
palazzopl
Default vacuum jumping
my 81 vacuum at idle jumps from 17 to 20. I just had the heads done and i'm wondering if I set the valves to tight. Any other causes for vacuum problem.
Old May 18, 2013 | 05:33 PM
scottyp99's Avatar
scottyp99
Here's a good article on how to use a vacuum gauge to diagnose an engine. Pay particular attention to scenarios 5, 8, and 15, in your case. Good luck,
http://www.secondchancegarage.com/public/186.cfm
Scott
Old May 18, 2013 | 05:43 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Varying vacuum is indication of a bad/leaking valve.
Does it vary at higher rpm?
cardo0
Old May 19, 2013 | 10:02 AM
palazzopl's Avatar
palazzopl
cardo0
at high rpm its ok .and I also have a hesatation when I accelerate. I have a can af sea foam I'll try to day. If no help I'll remove the covers and take a look
Old May 25, 2013 | 10:03 AM
palazzopl's Avatar
palazzopl
poured a half a can of sea foam down the carb and the rest in the gas tank. I let it sit for a few days then took it for a short ride. Everything seams to be ok now.
Old May 25, 2013 | 11:18 AM
scottyp99's Avatar
scottyp99
Almost everything can be fixed with Sea-foam, JB-weld, or a big hammer!
Scott
Old May 26, 2013 | 11:48 AM
Indiancreek's Avatar
Indiancreek
cardo0
I suspect the correct answer.
Old May 26, 2013 | 01:52 PM
scottyp99's Avatar
scottyp99
Sea-foam magically cured it!
Scott
To vacuum jumping
