HEADLIGHTS (Again!)
Old May 19, 2013 | 09:58 AM
psycho dad's Avatar
psycho dad
Default HEADLIGHTS (Again!)
Okay, I recently replaced all the hoses, both actuators and both relays.
Headlights worked great, for 2 weeks. Now right one pops right up, left on opens halfway and starts fluttering for several seconds, then eventually opens.
Of course this only happens when I'm out on the street, when I get home to take a look it usually pops right up.
I suspect I bought a bad part, either the relay or actuator. Any ideas or suggestions would be greatly appreciated.
- Jay
Old May 19, 2013 | 10:08 AM
palazzopl's Avatar
palazzopl
- Jay
I have an 81 had problems with new relays I connected both actuators to one relay, just T one off and cap off the other. works fine. also check your vacuum
Old May 19, 2013 | 10:25 AM
psycho dad's Avatar
psycho dad
I was running one relay before, courtesy of the previous owner. I just added the 2nd.
Old May 19, 2013 | 10:47 AM
TimberwolfFXDL's Avatar
TimberwolfFXDL
convert to electric?
Old May 19, 2013 | 11:26 AM
Dave J's Avatar
Dave J
Reproduction relays are known to have issues holding vacuum right out of the box. Was this new relay tested before installation? That would be my first reaction.
Old May 19, 2013 | 05:25 PM
psycho dad's Avatar
psycho dad
I did not test it before installation. Its actually been a few months since the problem started, but I think I swapped all the lines on the 2 relays and the right one do not have issues. But like I said it usually works fine in the garage.
I guess I was hoping someone would read this and know exactly what's wrong.
Old May 19, 2013 | 06:43 PM
kanvasman's Avatar
kanvasman
search the forum for "vacuum to electric NEW WAY", Probe motors, simple brackets & wiring set up. Then you won't have to worry about actuators, relays, hoses etc.
Old May 19, 2013 | 06:54 PM
Peterbuilt's Avatar
Peterbuilt
Try a few drops of penetrating oil in each port of the relay.
Old May 19, 2013 | 11:10 PM
psycho dad's Avatar
psycho dad
worth a try, thanks
Old May 19, 2013 | 11:35 PM
scottyp99's Avatar
scottyp99
This thread helped me out a lot when I had headlight problems:
http://forums.corvetteforum.com/c3-t...tem-works.html
Scott
Old May 20, 2013 | 07:30 AM
Mooser's Avatar
Mooser
Swap the hoses to each relay and see if the problem moves with it.
Mooser
Old May 20, 2013 | 07:52 AM
augiedoggy's Avatar
augiedoggy
Wilcox has posted videos on troubleshooting.... sounds like one of the rubber boot diaphragms is leaking... I bought a set for like 6 bucks and replaced them instead of the whole canister. I had the very slow lazy lights .
Old May 20, 2013 | 10:59 AM
psycho dad's Avatar
psycho dad
thanks guys. I'll keep looking.
Old May 20, 2013 | 01:51 PM
VetteNURSE's Avatar
VetteNURSE
I know exactly whats wrong, had the same thing. CHINEESE PARTS! I am on my 3rd set of actuators and 2nd set of relays in a year. Very frustrating. Willcox has been great, not their fault although it is taking 3 weeks to get the latest set back, they are way behind. What other options do we have???
Mike
Old May 20, 2013 | 02:17 PM
Dave J's Avatar
Dave J
Mike
Did you keep your original GM relays? If so, send them to me, I'll take care of the problem. If you have them, PM me, and I'll take it from there.
Old May 20, 2013 | 05:23 PM
psycho dad's Avatar
psycho dad
I'm sure you're right Vettenurse, they were perfect for 2 weeks.
No Dave, I didn't save the old ones, but I don't think they were GMs anyway.
To HEADLIGHTS (Again!)
