1975 Stingray Electric Fuel Pump
Old May 21, 2013 | 10:11 AM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default 1975 Stingray Electric Fuel Pump
My vette has a 96-00 vortec 350 5.7L and requires a electric fuel pump, presently it is installed just behind the front passenger wheel, I have been told it needs to be in rear. It is a Holley Blue pump and is working fine. Any suggestions where in the rear I could relocate the electric fuel pump without having to disassemble the car?
Old May 21, 2013 | 10:24 AM
SuperBuickGuy's Avatar
SuperBuickGuy
as long as it's lower than the tank - it's not an issue. That said, if you want to move it back - I agonized a long, long time over where to put the pump on my car - ended up attached to the transmission cross member. That really was the closest I could get it to the tank and still be below the tank
Old May 21, 2013 | 10:27 AM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Pump
Presently My pump isn't that far from yours it's mounted below the tank on frame behind passenger tire just below starter. So maybe just keep there.
Old May 21, 2013 | 12:03 PM
billcarson's Avatar
billcarson
i had a holley fuel pump installed by the po and it was way too loud.replaced it with a carter marine pump in the same location in front of the rear bumper and have had no issues.quiet also.good luck.
Old May 21, 2013 | 12:57 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Fuel pump
Thanks and nice, what is the other thing mounted there?
Old May 21, 2013 | 01:02 PM
7t9l82's Avatar
7t9l82
fuel filter
Old May 21, 2013 | 01:16 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Fuel Pump
Holley is loud especially up front.
Old May 21, 2013 | 01:40 PM
SuperBuickGuy
here's where mine is
Old May 21, 2013 | 01:44 PM
bashcraft's Avatar
bashcraft
Ideally, electric fuel pumps should be mounted as close to the fuel tank as possible. They push much better than the suck. That's why you also want it lower than the tank.
That said, if you aren't having any problems with it mounted where it is, I wouldn't bother moving it.
Old May 21, 2013 | 01:45 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Fuel Pump
Looks like back side of cross member. How is the noise at that location?
Old May 21, 2013 | 05:11 PM
SuperBuickGuy
Given the tank is above the rear differential, above the frame, and the bottom being nearly level with the hood; I think finding a place where it isn't lower than the tank would be difficult
barely hear it when the motor is off - keep in mind, I run dynomax inserts (note I did not say mufflers) and side pipes; so I'm not sure I'd hear a Holley black mounted to the back of the driver's seat.
Old May 21, 2013 | 06:47 PM
7t9l82's Avatar
7t9l82
not trying to be a know it all but, an electric fuel pump is made to be as near and below the fuel tank as possible. the are not for use in the engine compartment due to heat and other factors leaks , shorts etc. i agree the holley pump is noisy, but it is easy to tell if its running.
Old Jun 25, 2013 | 08:11 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default 75
Ran car today would not idle checked fuel pressure gauge showed 0, it also surged I increased idle new edelbrock. Any suggestions
To 1975 Stingray Electric Fuel Pump
