What mod to do next
Check out these heads:
http://www.speedwaymotors.com/Flo-Te...lug,25118.html
Car Craft did a test including these heads, they made comparable power to vortec heads:
http://www.carcraft.com/techarticles...t/viewall.html
Scott
Scott
* Comp Cams XE268 high energy cam - Coated by HPC coatings with a dry film lube to increase lifetime
* Comp Cams hydraulic lifters purchased with the cam (I have tagged these when they were removed to ensure you install them back in the same position as lifters will 'mate' with their lobe of the cam and you shouldn't move them)
* Chevy 041 casting cylinder heads with
* 62cc combustion chamber
* chamber has been clearanced to unshroud the larger intake valve
* 2.05 Ferrea 5000 series intake valves
* 1.60 Ferrea 5000 series Exhaust valves
* Comp Cams spring to match cam (bought with the cam as a set) - These have been coated by HPC with a dry film coating to help oil flow over them and increase useful life
* Moroso pushrod guide plates
* ARP 3/8 inch screw in rocker studs
* The heads have been ported by a previous owner
* all the work I had done on the heads was performed by Boyettes Racing shop in Raleigh. Before I installed them they made sure everything was good and installed the new valves (3600 miles ago)
* Accessory bolt holes have been drilled in the front of the heads to allow for the alternator mount (atleast on my 78, what year was your car?)
* I have the set of ARP head bolts that were used to bolt them in on my old motor. I bought new but will throw these in if you want them (probably still better than stock bolts)
* Comp Cams 1.52 ratio roller tip rockers
* Comp Cams double roller timing chain set with cam timing adjuster (I dialed in the cam when first installed and verified that it was ground correctly, so you should just have to install it.
The reason I post this is based on my own experience. Once the horsepower bug hits,...you'll need to upgrade fuel delivery, cooling system,exhaust,...driveline,.....tires,. ...all expensive. I did three transmissions before I ended up with one that held up to my 540 horse 406.
The 350 you have should get 17-20 mpg and last 120,000 miles,..I built one like it, and drove it six years daily, year round. The 406 I have now gets 11 mpg, and I hardly drive it at all now.
These 041 heads were my personal journey down the path of trying not to spend $2K on great aluminum heads. In the end, I spent almost that much on these getting them worked and redone. Lesson learned (and a new set of AFR 195 eliminators are taking their place
). So like many of you, I have now spent WAY too much on heads for the vette.That said, I'm working with KuhnDar to compute his static and dynamic compression ratios to see if the parts are even a good fit for his bottom end. Nobody has any interest in another member bolting up stuff that's just not going to be happy together.
Also, these parts came out of a 4-speed car with a 3.70 rear. KuhnDar, is your car an auto or a 4-speed and do you know the rear end ratio?
Having been down this path before with building an engine, you should be aware that you will most likely also have to buy pushrods (if the length required is different for the new combo) and I am sure that there will be other expenses as well.
As stated above, these types of upgrades can be addictive (my motor was built only 3600 miles ago and I am tearing it apart again to get more power). It's a fun journey, but it ain't cheap
If your budget is the overriding factor, I would agree that the best route may be to simply refinish what you have, re-assemble the car and enjoy the heck out of it.
