Tire pressure
Old May 25, 2013 | 02:37 PM
VetteNURSE's Avatar
VetteNURSE
Default Tire pressure
What pressure for bfg t/a 255 60 15?
Old May 25, 2013 | 03:11 PM
BPHORSEGUY's Avatar
BPHORSEGUY
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
30-32 lbs cold!
Old May 25, 2013 | 04:22 PM
yyz1970's Avatar
yyz1970
35 max cold
Old May 25, 2013 | 04:33 PM
Miccar's Avatar
Miccar
Does running less pressure in the tires help reduce stress cracks from developing in the body?
Old May 25, 2013 | 06:00 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Vehicle manufacturers have been know to fudge inflation pressures for their own reasons (most commonly ride comfort), but I wouldn't advise setting them by any other criteria than those that fall within a given tire manufacturer's recommended minimums and maximums which yield the most even tread wear under normal operating conditions. Noting that spirited driving &/or racing aren't exactly normal conditions, the above may still prove somewhat more applicable than one might think.
IMCO, if you've already got a weak frame you most likely can't safely reduce tire pressures enough to lower your effective wheel rates to a point where it will make much difference. Bottom line: Don't compromise your tires, as they're the only thing keeping you out of the ditch. Fix the frame. My $.02
Old May 25, 2013 | 07:29 PM
speedreed8's Avatar
speedreed8
my oem 79 door sticker has 30 front, 35 rear. 255-60/15
To Tire pressure
