'69 Steering Wheel Replacement
Old May 26, 2013 | 03:59 PM
bucket's Avatar
bucket
Default '69 Steering Wheel Replacement
How do you remove the steering wheel on a 1969 vette?
Old May 27, 2013 | 09:43 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Non Tilt.
Remove the horn button,
Remove the upper contact Screws,
Remove the screws that hold the wheel to the hub...
Tilt
Remove the lock star washer screws first marking location.
Remove the star bolt, and tele locking ring.
Go to this link and start at the top.. it will walk you through this.
http://willcoxcorvette.com/repairand...lp.php?hID=313 click on supporting document.
Willcox
Old May 27, 2013 | 07:03 PM
bucket's Avatar
bucket
Originally Posted by Willcox Corvette
Non Tilt.
Tilt
Willcox
I'm curious about something: When is a steering wheel puller required, if ever?
Old May 27, 2013 | 07:13 PM
0Willcox Corvette
Former Vendor
This tool is called a steering wheel puller since most cars had the steering wheel incorporated into the lower hub.
When it it needed? When you need to pull the hub to service the turn signal switch or any of the parts below the hub.
Willcox
Old May 28, 2013 | 05:25 PM
bucket's Avatar
bucket
Willcox
Old May 29, 2013 | 11:03 PM
0Willcox Corvette
Former Vendor
Not a problem at all..
To '69 Steering Wheel Replacement
