This may sound silly
Old May 28, 2013 | 01:40 PM
hardlanding's Avatar
hardlanding
Default This may sound silly
but is there any headers out there for the small blocks that are set up to run with the smog equipment
Old May 28, 2013 | 02:14 PM
pauldana's Avatar
pauldana
I have not seen any since the introduction of the catalytic converter... the reason is the catalytic has to run very hot to do to the convertation of the gases, it is so named because it converts the three main pollutants in automobile exhaust: carbon monoxide, unburned hydrocarbon and oxides of nitrogen. The first two undergo catalytic combustion and the last is reduced back to nitrogen... but it has to run hot, and long tube headers do not do this well. back in 1972, my Jeep CJ5 had headeres with the ports built in for the smog pump. but shortly after that the catalytic converter was introduced and thoes headeres went way..
Old May 28, 2013 | 02:16 PM
gcusmano74's Avatar
gcusmano74
Part B of that is that most of the guys that run headers have already thrown the AIR pump in the trash, thinking they were improving things.
Old May 28, 2013 | 02:34 PM
pauldana's Avatar
pauldana
it does improve things at upper RPM with flow, thus more HP.... but does nothing much at low RPM's
Old May 28, 2013 | 03:00 PM
hardlanding
i wanna keep the AIR pump, and the cat...is that a counter productive approach?
Old May 28, 2013 | 03:06 PM
pauldana's Avatar
pauldana
if you want to stay stock no..... if you want to race yes....if you are keeping both, you have to stay with the stock exhaust as far as I understand..
Old May 28, 2013 | 03:16 PM
hardlanding
I want it to improve preformance and pass state inspections
Old May 28, 2013 | 03:18 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
there are headers with air tubes
Old May 28, 2013 | 03:31 PM
hardlanding
I can't seem to find them
Old May 28, 2013 | 03:36 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
hooker
it is a era thing.
back when air pumps ruled, headers were made with the nozzles.
since the pumps are long gone, gonna be a hard find.
Old May 28, 2013 | 03:57 PM
scottyp99's Avatar
scottyp99
Just about any header can be modified to accept those pipes, you'll just have to throw some money at it. How much? Couldn't say. I can't imagine it would be that much, though.
Scott
Old May 28, 2013 | 06:07 PM
doctorgene's Avatar
doctorgene
Yes Sir; General motors had a production set of Stainless Steel, block huger headers, on the 1981, 1982, & 1980 Cal. 305 Corvette's. Bolt right on with the Air Pipes welded in by the Factory. G. M. stated that it added around 14 H. P. There are some still around on the Corvette Forum. & I think one guy is taking them, adding Powder Coat, & reselling them. I Have a couple sets myself. Which I coated with Por 15 header paint. You can tell the added H. P. is there. Have a great one. Gene
Old May 28, 2013 | 06:11 PM
pauldana's Avatar
pauldana
Shorties for sure, I doubt they are long tube...
Old May 29, 2013 | 08:40 AM
hardlanding
would you be intrested in selling a set
Old May 29, 2013 | 09:02 AM
Jig A Low's Avatar
Jig A Low
there are long tube headers with air tubes in them available, they also sell a "kit for installing the air tubes in just about any brand of headers. the headers that are built with the air tubes are expensive but available. you may have to call summit, they don't list them on the site but they can get them.
Old May 29, 2013 | 09:07 AM
pauldana's Avatar
pauldana
But the cat will not work with long tube... And it will fail smog...
Old May 29, 2013 | 10:23 AM
texas jim's Avatar
texas jim
My '81 came w/ those stainless block hugger headers, and w/ the air tubes. I took them off and installed long tube headers. Got rid of all the smog devices. I still have them laying around if you're interested. They supposedly flow better than the cast manifolds and are a lot lighter.
To This may sound silly
Old May 29, 2013 | 11:53 AM
qwank's Avatar
qwank
here you go, seems easy enough to weld them on:
http://www.summitracing.com/parts/hed-22830
Old May 29, 2013 | 12:41 PM
doctorgene's Avatar
doctorgene
Yes Sir; Thanks for asking, but no, I want to keep them handy just in case. I have thought about installing them on my 77. I also have a set of 2.5 inch off a 1986, I don't know if they will fit or not. texas jim is the guy you want to talk to. Have a great one. Gene
Old May 30, 2013 | 09:07 AM
hardlanding
I'm sorry if I seem like i am dragging this out but, if i go with them (the factory shorties) ill see about 15 HPs right vs. about 30 for longtubes, and the factories are a better fit up, and with out the heat issues?
