74 heads
Old May 29, 2013 | 10:58 PM
redwhitekat's Avatar
redwhitekat
Default 74 heads
What are the best bang for the buck heads for a 74 l82 motor nothing to crazy but something nice ? Any recommendations
Old May 30, 2013 | 08:28 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Best bang for the buck? Well, I'm happy with my AFR 195 Street Eliminator heads on my '76 L-82 that were installed last year. This year, I'm in the process of putting in a retro hyd roller cam - .560" lift, 227 duration @ .050". A big bang over stock for a bit more than a buck but very nice.
Old May 30, 2013 | 08:32 AM
Marlin's Avatar
Marlin
Whats your budget?
Vortec heads cleaned up are a good bargin.
The name brand companies like edelbrock have economy alum heads that work well.
Old May 30, 2013 | 09:00 AM
redwhitekat
I see those afr heads their about 1500 from summit are they s big inprovement as far as performance goes ??
Would I have to get the carb retuned after I install one of these
Old May 30, 2013 | 09:37 AM
jackwabbit703's Avatar
jackwabbit703
I got brodix 200 cc heads and couldn't be happier but it will cost u.
Old May 30, 2013 | 09:41 AM
4 speed's Avatar
4 speed
I agree with the vortecs, 906 or 062. from what I understand, they are the best flowing stock GM sbc head.
Old May 30, 2013 | 09:57 AM
redwhitekat
How does the bottom end of the engine hold up with an updated heads
Old May 30, 2013 | 10:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Best Bang for your Buck: the stock L-82 pair. They're the best you could get at the time and didn't cost you anything extra.
Old May 30, 2013 | 10:29 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
I agree with Mike. I port matched mine since the intake ports were not cast very evenly and did a nice valve job on the factory 2.02/1.60 valves. For a driver quality car that I like to cruise in as well as take on trips it works very well. I'm sure that an expensive (to me) set of aluminum aftermarket heads would give me some extra grunt in the mid to upper RPM ranges but since I rarely push my Vette that much or that hard I'm happy. I have abundant low and midrange power with my combo. To each his own, but I can spend $1500+ on better stuff for my baby.
Old May 30, 2013 | 10:56 AM
Mike Ward's Avatar
Mike Ward
You're not expecting big gains from a set of heads on an otherwise stock engine I hope.
Old May 30, 2013 | 11:58 AM
redwhitekat
I need new valve guides so to recondition my heads I'm looking around 1500 for 2 new heads mid of the line I'm looking at 1000 I'm not looking for big gains. I'm just not confident I can do the replacement myself so I prob need a shop to do it
Old May 30, 2013 | 12:39 PM
augiedoggy's Avatar
augiedoggy
how do you know you need new guides and not just seals? Have the heads been removed and pulled apart yet? $1500 for valve guides and seals? Make sure the rest of your engine isup to the task.... worn rings can easily give out under increase in pressure from better flowing or higher compression heads.
Old May 30, 2013 | 12:48 PM
augiedoggy's Avatar
augiedoggy
I started Dow. The same road when I picked up my dart heads on Craig list for my 74 and ended up deciding to change the whole engine. But if your block is in good shape you can get a nice boost with 64/180cc heads.
Old May 30, 2013 | 12:58 PM
cv67's Avatar
cv67
St. Jude Donor '05
You can get nice gains with the afrs and a stock cam
No matter where that lifter is on the lobe once the valve is open it will move more air than the stockers. Id recommend a little better intake/exh to compliment it.
Not a fan of dumping money in old iron heads. Vortecs are way overrated imo. And known for cracks so beware.
learned my lesson the hard way- buy the best cyl head you possibly can the first time. You can always add other parts to help compliment later but at least they are there. The bottom end wont be affected by a new head. If it goes it was gonna anyway.
Most blow up bottom ends after cam/head upgrades from driving them like they stole them lol. Never had an issue personally just dont be a dope with the pedal.
To 74 heads
