Tranny gears reverse?
Old May 31, 2013 | 04:16 PM
jsz31's Avatar
jsz31
Default Tranny gears reverse?
I had my tranny rebuilt a while back for my 78 vette. It is an automatic, well, finally got it in and finally went to move the car and found the gears are reversed. drive is reverse reverse is drive Did I hook the linkage up wrong? Did I not have the only lever on the tranny in the correct position when I hooked up the cable? I called the shop that rebuilt the tranny and they thought the pump was messed up, that I snapped it when I tightened the bell housing ,by not having it aligned properly on the flywheel. But they said I shouldn't have reverse and I do Please tell me it is something simple like the linkage is in wrong place? Shop said they will get back with me Did the instulation from the floor with car jacked up and on stands, sure hate to remove it again
Old May 31, 2013 | 04:52 PM
mrvette's Avatar
mrvette
The auto trans control lever on the left side of the trans is installed upside down, the lever should stick UP and then the shifter cable attached....even if my mammary is rong, just flip the piece of steel the other way and it's fine.....
Old May 31, 2013 | 07:07 PM
jsz31's Avatar
jsz31
Thanks I will try that in morning and see what happens
Old Jun 1, 2013 | 07:41 AM
diehrd's Avatar
diehrd
Yes you hooked it up wrong . disconnect linkage , go under car and put it in park , to know it is park try to rotate the wheels. Now move it to neutral and connect your shiftier cable.
Old Jun 1, 2013 | 11:14 AM
jsz31's Avatar
jsz31
I went under it this morning and the linkage was upside down from the shop and I never paid attention to it , switched it around and works except is there a adjustment on the cable , it is hard to get it in park all the way I have to put alittle pressure on the shift lever to start it and also have to use some force to get it into first if I want to use the shifter. works great in drive
Old Jun 1, 2013 | 11:16 AM
diehrd's Avatar
diehrd
Did you set it in N when you hooked cable up ? If you did , go back and disconnect the cable again , pull it into low and hook it up and see how that works.
Old Jun 1, 2013 | 11:22 AM
jsz31's Avatar
jsz31
actually I did not I just took the bolt off , flipped it around and tried it Your saying put it in first (low) after i disconnect the cable then move the klever to hook cable back up?
Old Jun 1, 2013 | 11:23 AM
diehrd's Avatar
diehrd
The correct way is put it in neutral , hook it up then test it. It should be good doing it that way .
Old Jun 1, 2013 | 11:33 AM
jsz31's Avatar
jsz31
Ok I'll try that tomorrow , I am now on a to-do list buying some shrubs and planting also replace a screen door, Tomorrow I believe is my day I'll let you lnow if that works
Old Jun 2, 2013 | 05:13 PM
jsz31's Avatar
jsz31
Well corrected my tranny linkage hook up it shift great for 2 or 3 minutes then stayed in drive only looked under and found cable pulled out of plastic shield and bent Ordered a new one Rather it had broke in garage then out somewhere just how my e
Week has been going
To Tranny gears reverse?
