Check out a Richmond 6 spd.Got one in my 76 and its a great match with the 3.08 rear gear.For optimum performance match the trans to your rear gear ratio.To much or to little first gear and or OD gear and you end up with a not so good swap.
I know. A 3.27 is not an option since I run 4.11's in the back to help low end torque.
Would like to go overdrive but a price tag of 4000 is a bit over it I think and used these are not to be found either I think.
