Battery Keeps draining
Old May 31, 2013 | 04:45 PM
stinger77's Avatar
stinger77
Default Battery Keeps draining
Hi, im new to the forum. i bought my 77 vette when i was 16 and have been working on it little by little for the bast few years now. i finally replaced the batter so that i could start the car more often since i just redid all the breaks, and after a week of not starting the car, i find the new batter dead. the car wouldn't make a sound when i turned the key. As this could be from anything, does anyone have suggestions as to what to check first?
Old May 31, 2013 | 05:22 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default battery
When your car is not is use, disconnect the negative battery cable to the frame location, easy, takes only seconds.
The glove box light could be staying on draining the battery.
Old May 31, 2013 | 05:34 PM
Peterbuilt's Avatar
Peterbuilt
Default Hi and welcome again.
Here's a very good how to:
http://forums.corvetteforum.com/c3-g...with-pics.html
1977 schematic:
http://www.vetteprojects.com/bmv/mis...tte%201977.pdf
Old May 31, 2013 | 09:56 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Have you had the altenator checked? Mine did this when it was bad.
Old May 31, 2013 | 10:26 PM
stinger77's Avatar
stinger77
yes, alternator is new. it has no glove box, it has the accordion style pockets. the previous owner removed the ac system (crudely), so i wonder if that might have something to do with it. petes74ttop, thank you for the links, they both look very useful. ill have to give this a try this weekend
Old May 31, 2013 | 11:25 PM
couperdecar's Avatar
couperdecar
For some reason my '79 was doing this when I 1st bought it. I installed a battery disconnect and used it the 1st year. I still have the battery disconnect installed but the electrical system must of got scared because I've left it connected for many years and NO PROBLEMS.
If you can't find your problem - install a battery disconnect. Besides when I work on any electical issues , it takes me 2 secs to remove the battery from the work problem.
Old Jun 1, 2013 | 05:51 AM
nz corvette's Avatar
nz corvette
Hi I have a 77 that had the same problem, it was the dimmer relay under the dash pad just above the tacho,unless you want to pull the pad off (not a good idea) and unplug it, I would suggest disconnecting the door switches (which are behind each foot panel)which turn on your interior lights
good luck
cheers Dave
Old Jun 1, 2013 | 08:32 AM
roger3's Avatar
roger3
Check light in middle compartment behind seat (glove box light).
Roger
Old Jun 1, 2013 | 11:32 AM
hugie82's Avatar
hugie82
Under hood light killed mine...
Old Jun 1, 2013 | 12:19 PM
dochorsepower's Avatar
dochorsepower
One more thing to look for, the alternator wire bundle clamped behind the alternator can wear through the insulation causing an intemittent short to ground. It happened to mine ('75) and took a long time to figure out. These are old cars and a lot of odd little things happen.
Old Jun 1, 2013 | 07:14 PM
MakoJoe's Avatar
MakoJoe
I have 2 problems I have found in my 1977 the horn switch broke and the hood courtesy light switch is worn out. Today I went down to the auto parts store and purchased a battery cutoff switch so I quit draining my battery until I order the parts to fix the problems. if I still have a battery drain after I fix these 2 problems I will start looking again but so far these are the only 2 problems I have found.
For testing the circuits I purchased this light probe DORMAN/CONDUCT-TITE ELECTRICAL MULTI TESTER I chose this one because it also has an audio sound when I cannot see the light.
I went through the fuse box and then tested each courtesy light switch. This Probe will also allow you to poke into the wire harness if needed with a pin to Peirce the wire coating.
http://www.autozone.com/autozone/acc...ier=88099_0_0_
For long term storage these are also good so your not disconnecting and reconnecting the terminal leads which I can tell you is a pain in the butt.
http://www.autozone.com/autozone/acc...er=815834_0_0_
Old Jun 2, 2013 | 11:05 AM
jms 73's Avatar
jms 73
Navigator
An easy way to find a battery drain is to put an amp meter in series with the negative cable With everything off you should see close to zero amp draw.
If you see a draw pull the fuses one by one until the draw goes away. You will then know your troubled circuit and can investigate that circuit.
Don't forget your dome light will be on when you are checking the fuses.
Hope this helps
To Battery Keeps draining
