As shared in another thread, I am preparing to install a points style distributor after a mechanical breakdown with the HEI. The switch to the original style distributor forced a close inspection of the ignition wiring and I need help identifying the crinkled wire in the photo with the two insulators(?) It is orangish up close, but two red wires emanate out of the insulator in the back of the photo. No clue-
The white wire was cut and spliced with a red wire and plug to fit the HEI--the other side of the white wire was dead-ended, but still attached to the starter solenoid. Bubba visited two other spots in the wiring closer to the starter.
I would swap out that fusible link. Looks pretty bad. When I changed out my engine, I viewed my engine wiring harness and went with a new one. That 40 year old wiring on my car looked scarry.
Bubba may have put the switched power that goes to the dizzy as an extra wire to the starter. Not really sure though as mine is hooked up with an MSD box.
Those 2 nasty looking wires coming out of the black cylinder looking thing are the fusible links.
Thanks, this pdf really helped me understand the fusible links--http://content.chiltonsonline.com/content/images/9071/images/9071fig639.pdf
