Trailing Arm Movement, Is this Normal?
Old Jun 1, 2013 | 06:21 PM
cwvett79's Avatar
cwvett79
Default Trailing Arm Movement, Is this Normal?
Rebuilt trailing arm with new spindle. Half shaft replaced with new U Joints.
Noticed a lot of movement from the trailing arm and half shaft looks out of round in rotation.
The Video is of the lh side.
The rh side has very little movement.
Is this normal?
If its not does it look like I need a new Half shaft.
Craig
http://s1235.photobucket.com/user/wa...5c55a.mp4.html
Old Jun 1, 2013 | 07:43 PM
Vette-in-the-Veins's Avatar
Vette-in-the-Veins
To me, it looks like the u-joint is not sitting in the axle end yoke correctly.
Make sure that both of the u-joint caps are sitting in the yoke and between the raised portions in the yoke.
If it seems the caps won't go together close enough to fit in the yoke then check to see if some of the need bearing/needle rollers fell into the bottom of the u-joint end cap/bearing.
Old Jun 1, 2013 | 07:54 PM
Mike Ward's Avatar
Mike Ward
+1
just as important, don't run a C2/C3 Corvette up on jack stands with no wheels and the suspension hanging.
Old Jun 1, 2013 | 08:47 PM
cwvett79's Avatar
cwvett79
Ok, I will pull the half shaft again and check the u joints.
Thanks for the input
Old Jun 1, 2013 | 09:14 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
check the yokes in the diff for in/out play
Old Jun 1, 2013 | 09:18 PM
Peterbuilt's Avatar
Peterbuilt
Default Bummer.
[/url]
If you did not use a special tool to do that, then the flange might have bent.
Old Jun 1, 2013 | 10:02 PM
hugie82's Avatar
hugie82
At full droop the control arm might move up and down a little but something is out with the half shaft. It will vibrate like crazy with a wobble like that!
Old Jun 3, 2013 | 01:22 AM
cwvett79's Avatar
cwvett79
Found the problem, when I pulled the half shaft .
The yoke end u joint cap was not seated correctly
Because of a needle bearing mis aligned.
I never have time to do it right the first time ,But I always have time to do it right the second time!
Old Jun 3, 2013 | 08:53 AM
Mid-Years Forever!'s Avatar
Mid-Years Forever!
Originally Posted by Mike Ward
+1
Mike,
Can you elaborate a little, for newbies like me? Is it because at full suspension-extension, the half-shaft u-joints are pushed passed their normal range of motion?
Or am I all wet?
Thanks.
Peter
Old Jun 3, 2013 | 09:32 AM
gcusmano74's Avatar
gcusmano74
On a C2/C3 rear suspension, the amount of downward travel is controlled by the length of the shock absorber. If it is more than about 14" long, the Ujoints bind at full droop.
Old Jun 3, 2013 | 10:56 AM
Mike Ward's Avatar
Mike Ward
Yup.
To Trailing Arm Movement, Is this Normal?
