Smoke from wheel well.
Old Jun 3, 2013 | 04:10 PM
AirwolfPJ's Avatar
AirwolfPJ
Default Smoke from wheel well.
Came back from a Dr. appt and pulled into the garage. Noticed smoke coming out of the rear wheel well on the driver's side. Tried to look underneath from behind but couldn't see anything - and played heck trying to stand back up. Any ideas what could be the cause? Gonna have to wait till the back is better anyways....lol.
Old Jun 3, 2013 | 04:35 PM
Zorro O's Avatar
Zorro O
All that comes to mind is.
1. You have a lead foot.
2. Your E-brake was on.
3. You have a brake dragging.
4. You have something stuck to the exhaust.
5. Something has shifted and you have a tire rubbing.
6. If you live in Seattle or Denver, a hippy could be living under there.
7. Their is a fuel return line that runs back under there.
8. Check your main battery cables under the battery box.
What color was the smoke, what did it smell like?
Old Jun 3, 2013 | 05:29 PM
scottw's Avatar
scottw
Rear bearing, brakes (Calp or Ebrake), exhaust.
Old Jun 3, 2013 | 05:48 PM
Mooser's Avatar
Mooser
I'll vote for collapsed flex line to the brake
M
Old Jun 3, 2013 | 05:53 PM
LS4 PILOT's Avatar
LS4 PILOT
brake or bearings
Old Jun 3, 2013 | 07:54 PM
AirwolfPJ's Avatar
AirwolfPJ
Yeah, I'm thinking either brakes or bearing. Hoping it's the brakes as I'm not sure if I'm ready to tackle the bearings.
Thanks for the replies everybody.
Old Jun 3, 2013 | 08:39 PM
Peterbuilt's Avatar
Peterbuilt
M
Start here, this is a good guess!
Old Jun 6, 2013 | 06:50 PM
AirwolfPJ's Avatar
AirwolfPJ
Got it fixed. Passenger side rear caliper was leaking. Driver side rear hose was collapsed. And Bubba decided to run a new brake line and attach it to the bottom of the frame. Seems the brake lines won't hold up very well as a surface for the floor jack to contact. lol New calipers, pads, hoses, and brake line.
But I did find out what the clunk noise from the rear was that I heard on occasion. The spare tire carrier was empty and had some up and down play. Fixed it also. Rear bearings checked out fine as did all the u-joints.
On to the next project....
Old Jun 7, 2013 | 07:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by scottw
...Rear bearing, brakes (Calp or Ebrake)...
To Smoke from wheel well.
