Oill leak - starter area
Old Jun 7, 2013 | 08:26 AM
Iron_dog's Avatar
Iron_dog
Will a smoke machine detect such leaks?
I can have one available...
Old Aug 27, 2013 | 01:01 PM
CAMS69's Avatar
CAMS69
Default hmmmmm
you never know...
on the front of the engine on the passengers side, right in front of the fuel pump there's a threaded hole that goes all the way through to the
oil pump pushrod, at high speed / hi rpm it can spew oil..IIRC
Heres a thread that shows it
http://www.chevelles.com/forums/showthread.php?t=318668
Old Aug 29, 2013 | 09:25 AM
Iron_dog's Avatar
Iron_dog
Originally Posted by CAMS69
you never know...
Thanks man, I've already checked that hole, I have a screw in it so it should be ok... I've just ordered a dye for the oil and an UV light.... let's see if I am able to solve this problem! thanks
Old Aug 29, 2013 | 11:31 AM
scrappy76's Avatar
scrappy76
Looking at the pics. I am going to say valve cover gasket or intake Manifold. if you look at your exhaust pipe, there is only oil from the starter back. There is no oil on the front of it. That would make me think it is not coming from the fuel pump mount nor from the fuel pump rod bolt.
There is oil all over your firewall going up pretty high, so might be more than one leak.
I sent you a pm about your avatar.
Old Aug 29, 2013 | 12:27 PM
yyz1970's Avatar
yyz1970
I would check the back of the engine at the top (oil pressure sensor?)
Old Aug 29, 2013 | 12:43 PM
Richard Cooper's Avatar
Richard Cooper
Originally Posted by MotorHead
Oil will flow to the lowest part on the motor. Invest $30 in a leak detection kit at NAPA, I have had one for years and they work great, it will usually surprise you at where the leak is coming from
Old Aug 29, 2013 | 01:32 PM
tyancey00's Avatar
tyancey00
let us know how the uv thing works...
Old Aug 29, 2013 | 01:49 PM
mikejpss's Avatar
mikejpss
From: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
Originally Posted by Arkyvette
My 82 has this same leak. I was thinking rear main seal slinging it around and ending up there.
my best guesses.
Old Aug 29, 2013 | 02:18 PM
garygnu's Avatar
garygnu
if the rear seal was leaking would that cause the clutch to slip ?I say you have a leaking oil pan gasket .consider a 1 piece rubber oil pan gasket .
Old Aug 29, 2013 | 02:39 PM
keithinspace's Avatar
keithinspace
Honestly, guys, I think it is the high pressure line going the oil pressure guage. My car looked EXACTLY like that and everyone suspected the main seal...until I talked to someone who knew what they were talking about.
The fitting is located at the rear of the engine behind the intake. There is a little nylon hose that leaves it and goes into the firewall.
That nylon hose is in the high pressure side of the oil pump, so even the smallest of cracks can lead to a seemingly huge amount of oil showing up.
There is a replacement you can do with a copper tube instead of the stupid nylon hose. It is a little tricky to find the ferrules you'll need to mate to the fitting behind the oil pressure guage in the dash.
I replaced mine and my oil loss went from PAINFUL to damn near zero. Just from that one fix.
Old Sep 5, 2013 | 06:20 AM
Iron_dog's Avatar
Iron_dog
Guys I'm a married guy so I have very little time right now in order to use the UV stuff (even if I have already bought it!). But I'm also interested to understand better where to look at when I will have finally time to work on the leaking baby...
Iron_dog's Avatar
Iron_dog
Isn't the oil sensor on the top of the oil filter in the driver side of the block? thanks
Old Sep 5, 2013 | 06:22 AM
  #33
Iron_dog's Avatar
Iron_dog
How hard is to replace a oil pan gasket? any FELPRO PN to suggest as replacement? thanks
Old Sep 5, 2013 | 07:53 AM
  #34
Iron_dog's Avatar
Iron_dog
One thing I have forgot to say: oil leak is much (much) more when I reach higher RPM (above 2500RPM)... if I drive like a granny almost no leak...
Old Sep 17, 2013 | 07:35 AM
  #35
Iron_dog's Avatar
Iron_dog
Here we go. Put the UV stuff, I've marked the area where the oil comes from....
Old Sep 17, 2013 | 07:36 AM
  #36
Iron_dog's Avatar
Iron_dog
Also I've noticed there's some strange metallic tag coming from the block, what is it?
Old Sep 22, 2013 | 04:29 PM
  #37
JDavila's Avatar
JDavila
Any luck with the source of the leak?
To Oill leak - starter area
Old Sep 22, 2013 | 04:42 PM
  #38
Iron_dog's Avatar
Iron_dog
It comes from the back of the starter so it should be I'll pan gasket or main seal... I've bought both and I'm waiting for them to arrive!
Old Sep 22, 2013 | 05:55 PM
  #39
Peterbuilt's Avatar
Peterbuilt
That's a shim, some starters need them some don't.
Old Sep 23, 2013 | 08:59 AM
  #40
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Pretty easy to find the leak with UV oil detection kit, everyone should have one, you can use it for brake leaks and cooling system too
