72 Horn Relay Question
Old Jun 6, 2013 | 08:01 PM
Griff2002's Avatar
Griff2002
Default 72 Horn Relay Question
Ran horn diagnostics which suggested horn relay was bad. When I hooked up the new one it gets hot. Why would this happen? Could I have hooked up the green and black wires backwards (old relay looked different than stock, but assembly manual suggests green wire goes to middle terminal).
Green wire is not hooked up in picture, but shows where I had it plugged in. When I unplug the green wire the relay cools off.
thanks
Old Jun 6, 2013 | 10:07 PM
Peterbuilt's Avatar
Peterbuilt
Does the help?
http://www.vetteprojects.com/bmv/mis...tte%201972.pdf
Old Jun 7, 2013 | 08:40 PM
Griff2002's Avatar
Griff2002
Originally Posted by petes74ttop
Thanks Pete. The wiring diagram is going to come in all too handy I'm afraid. Anyway, I confirmed that I had the wires on the relay backwards, which explains the heat. I can run the black wire from the relay to ground and the horn works. Next step is to see if it's something in the steering column that's causing the problem.
Old Jun 8, 2013 | 12:20 PM
Griff2002's Avatar
Griff2002
Thought I had the problem narrowed down to continuity in the steering column. But low and behold when I put the connector back together the horn started working! Must have had a bad connection there. Many thanks to all the good posts on the forum to help work through this.
To 72 Horn Relay Question
