C3 Novice Needs Advice
Old Jun 7, 2013 | 11:44 AM
Robert Butler's Avatar
Robert Butler
Default C3 Novice Needs Advice
Gentlemen once again I would appreciate your technical input: My 80' C3 project car received two rebuilt stock front brake calipers from a well respected brake service rebuilder a year ago. These people are used by a number of MA Corvette restores with fine results I'm told.
They installed the stainless interior parts to prevent corrosion to upgrade them from stock. At that point , the car was off the road through the New England winter as I worked on the fuel system and wiring in my garage. This spring I have now found that one of the calipers is leaking brake fluid. Since I cannot drive the car in the winter, do I have to switch to another caliper set up that is more able to handle a car that sits through the winter ?
I do not race or drive fast so was perfectly happy with the stock calipers performance.
Thank you.
Robert
Old Jun 7, 2013 | 11:54 AM
jnb5101's Avatar
jnb5101
did you flush the lines before you installed the new calipers? it might be debris from the brake lines that damaged the caliper. or, it might simply be a bad-out-of-the-box part. in any case, flush the lines and either rebuild the caliper(not a difficult job) or, see if the supplier will exchange it.
Old Jun 7, 2013 | 11:57 AM
redman76's Avatar
redman76
St. Jude Donor '09
The stock calipers are fine, but prone to leak, especially if they sit for a long time. You will want to look at the stock calipers with the o-ring design which reduces chance of leaking. Your brake guy should be able to do for you. I had mine rebuilt by VanSteel with O-ring design and zero leaks so far. That was 3-4 years ago . . .
Old Jun 7, 2013 | 12:43 PM
LoneStarV's Avatar
LoneStarV
Most of the resellers use Lone Star calipers....they make a very good product and shouldn't leak. Call the vendor you bought it from and tell them what happened they should replace it for you.
Old Jun 7, 2013 | 02:16 PM
qwank's Avatar
qwank
My car sits in NH over the winter months. I've had it 3 years and only had on piston on one caliper leak so far. Luckily, mine are already all sleeved so I just keep a few sets of caliper seals on hand in case I get a leaker.
Old Jun 7, 2013 | 03:16 PM
billsfan's Avatar
billsfan
I replaced my two rear calipers with Cardone units from autozone 4 years ago. I flushed the entire system at the same time. The car sits in a cold Buffalo garage all winter, and only gets driven 1000 miles a year, no sign of a leak.
To C3 Novice Needs Advice
