removing rotors
Old Jun 7, 2013 | 12:21 PM
fuzzyz's Avatar
fuzzyz
7th Gear
Default removing rotors
First I'd like to say thanks for the help given on my steering column.
I'm having a hard time getting the rotors off. I read in the tech tips I need to drill out rivets to remove rotors. Is this true, I'm use to just pulling off the rotor.
Old Jun 7, 2013 | 12:25 PM
Mike Ward's Avatar
Mike Ward
Yes it's true and it's also a mistake to remove them in most cases. Research rotor run-out on this site.
Why do you want to do this?
Old Jun 7, 2013 | 12:39 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Mike Ward
...Yes it's true and it's also a mistake to remove them in most cases...
Do not pull the rotors unless 100% necessary.
Old Jun 7, 2013 | 12:41 PM
donyue's Avatar
donyue
Yes, the rivets have to be removed in order to remove the original rotors.
As mentioned it is not the best thing to do because the rotors and hubs would have been trued/balanced as complete units from the factory so if you replace the rotors the balancing might be out causing you to require rotor balancing to be done on the car.
With that being said I did replace my rotors without any problems. Use cobalt drill bits to drill the rivets out.
Old Jun 7, 2013 | 01:09 PM
racerx1's Avatar
racerx1
I removed my rear rotors last weekend. Search "rotor rivets". The below thread pretty much covers it....with nice pics.
http://forums.corvetteforum.com/c3-t...or-rivets.html
Old Jun 7, 2013 | 02:16 PM
gcusmano74's Avatar
gcusmano74
Runout on the C2/C3 brakes is very critical.
Don't remove the rotors without a very good reason.
(The rotors on my 172,000 mile car have never been cut).
Old Jun 7, 2013 | 06:37 PM
LT-1 kid's Avatar
LT-1 kid
I stopped removing rotors a few years ago,
Old Jun 7, 2013 | 07:05 PM
dunit2myself's Avatar
dunit2myself
Yes to the cobalt drill bits, and keep them cool w/lube (wd40 or similar). I hope it`s not THAT tough to shim the run-out out of them I made a tool to use with transfer punch to get the drill centered.
Old Jun 8, 2013 | 02:17 PM
fuzzyz's Avatar
fuzzyz
7th Gear
THANKS FOR THE INPUT. Guess I,ll leave them alone for now. They don't look bad. One less thing to do for now.
To removing rotors
