1972 Window Handle Problem
Old Jun 7, 2013 | 07:22 PM
Miccar's Avatar
Miccar
Default 1972 Window Handle Problem
I have had to replace my window handle twice within the last year. Granted it's a cheap one that you pick up at Autozone for around $6, but I was wondering whats causing this. The handle works well for a few months then spins and doesn't move the window regulator unless you firmly press the handle in. The metal fitting on the handle and door doesn't look stripped. Is it just a weak handle retaining clip or just cheap metal? Someone told me the clear handles have a deeper fitting than the black handles and might work better. Has anyone had a similar issue? Thank you.
Old Jun 8, 2013 | 08:12 AM
Miccar's Avatar
Miccar
Anyone ever have this issue? How did you correct it?
Old Jun 8, 2013 | 08:49 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
I'd be guessing but my take on this is that someone left a worn out handle on the window crank too long and it ate up the teeth on the regulator.
http://willcoxcorvette.com/product_i...ducts_id=17075
The cheapo handles usually work just fine but if you have any wear on this shaft they usually strip out quickly. Especially if you have some regulator roller wear inside the door. (or basically any additional binding).
This will probably cure your issue.
Old Jun 8, 2013 | 08:54 AM
BHRIG's Avatar
BHRIG
Go to the Help section of any Auto Parts supply store (PEP BOYS,AUTO ZONE,ADVANCE) and get the better of the handles offered.....the ribbing
is cast deeper into the shaft......the one that you describe is not cast as well ,the mold has been used for 100 years and has to be replaced...
To 1972 Window Handle Problem
