Boil Over
Old Jun 24, 2002 | 10:22 PM
thamzid's Avatar
thamzid
Default Boil Over
How HOT does it have to get before you get a BOIL OVER with a 15 Lb. Radiator Cap.
My 81 got up to about 240 today and no Boiling. The temperature outside was 107 and I had the A/C going hard as it could.
Later
Ken {US Navy Retired}
[Modified by thamzid, 7:32 PM 6/24/2002]
Old Jun 24, 2002 | 11:30 PM
bigvette1's Avatar
bigvette1
Default Re: Boil Over (thamzid)
With a 50/50 mix and a 15lb cap the boilingpint is probably up to 260. However, an engine temp of 240 is way too hot! If the coolant is at a true 240 do you know how hot the engine oil is or the trans. fluid? Engine oil is probably 280 or more and starting to break down. Please do yourself a serious favor and investigage why you are running 240 regardless of the outside at 107 you should be able to maintain 200-210.
