Power steering adjustment
Old Jun 17, 2013 | 10:55 PM
Higgy76's Avatar
Higgy76
Default Power steering adjustment
My 76 has a slight pull L, been told there is an adjustment screw on the power steering unit, this true? Simple to do?
Higgy09
Old Jun 17, 2013 | 11:17 PM
oldalaskaman's Avatar
oldalaskaman
its on the control valve and there's a bunch of tech on it
Old Jun 18, 2013 | 04:45 AM
terrys6t8roadster's Avatar
terrys6t8roadster
steering pull might be related to the caster adj not right. the p/s adj control valve. if the adj isn't correct the valve will be directing pressure flow to one side of the cyl causing the steering to turn to one side. you should be able to see this happen with car on stands engine running. caster adj. to eliminate the pull is easy just trial and error and will not effect the toe setting. lets say your car pulls left, you need to increase the caster rh. loosen the rh upper control arm remove a shim from the front and install in rear, test drive, oops more pull left that's what I mean trial and error. take two shims from rear to front. ah that's better. Actually can't remember which way to move the shims. adding or subtracting shims on both changes camber, don't do that. I'll walk you through it if you decide you want to try that.
Old Jun 18, 2013 | 06:28 AM
Higgy76's Avatar
Higgy76
Thanks, think I'll let the pros handle it and stick to the simpler stuff.
Higgy
Old Jun 18, 2013 | 06:30 AM
Higgy76's Avatar
Higgy76
Oh, plan to get new tires, which first? Steering adj. or tires.
Higgy
Old Jun 18, 2013 | 07:21 AM
oldalaskaman
steering adjust is done with the tires off and the power assist cylinder disconnected, tires wont affect it. if your tires or alignment are bad, it wont make much difference. there's a preliminary test when you get the tires off and cylinder disconnected that will let you know if it needs adjusting or not. if it doesnt need adjusting ...dont
Old Jun 18, 2013 | 12:03 PM
my 76 ray's Avatar
my 76 ray
There's a lot more that can cause a car to pull ... alignment, brakes dragging on one side, low air pressure in a tire. Make sure you fix the right thing. If the steering adjustment is the problem you can jack up both front tires and start the engine and the steering wheel will turn by itself in the direction of the pull.
Old Jun 18, 2013 | 08:49 PM
Higgy76's Avatar
Higgy76
Thanks. A lot to learn.
Higgy
Old Jun 19, 2013 | 09:28 AM
71scgc's Avatar
71scgc
Get a chassis service manual for the year of your car. Steering adjustment procedure is outlined within.
Not hard to do, for anyone.
Carter
To Power steering adjustment
